rear wiper
Old Feb 18, 2015 | 01:32 AM
hydro st170's Avatar
hydro st170
Default rear wiper
I have a 2003 focus st170 and the rear wiper has stopped working. The water still comes out but no movement or noise from wiper or motor. Does this mean the motor is done and if so is it a easy job to replace it?
Old Feb 22, 2015 | 06:19 PM
minder's Avatar
minder
common fault on the focus mate they just give up easy to replace
remove black plastic cover on your hatch and just undo the 3
10mm bolts and the 13mm wiper nut and off it comes
Old Feb 23, 2015 | 05:45 PM
S2-MAN's Avatar
S2-MAN
Broken wires are also common on the focus. It's where the sleeve goes into the tailgate.
Old Mar 2, 2015 | 02:47 PM
hydro st170
Rear wiper motor arrived and as was told was just a case of removing the wiper arm bolt and then the 3 bolts and earth screw and out it came then reversed the process to put back in and it now works perfectly. Thanks for the help guys
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
