St170 help needed
Old Feb 12, 2015 | 08:27 PM
ricky_2006's Avatar
ricky_2006
Default St170 help needed
Advice please. Going to look properly in light but thought I'd ask.
So try and explain simply.
Turn car on this evening and pull forward then all of a sudden I can't steer steer atall. Feels WIERD.
I look under bonnet and aux belt had come off and brake fluid leaked out and all over floor.
Don't sound to clever does it.
I'm gussig power steering pump is fucked hence the steering and a hole in a pipe somewhere as no brake fluid.
Any suggestions just by what I explained. I understand it's hard unless you see it but tried to explain as much as I could
Old Feb 19, 2015 | 10:55 PM
hydro st170's Avatar
hydro st170
Hi did u get the problem sorted.Mine went the same way and it turned out to be the power steering pipes.
Old Mar 11, 2015 | 12:51 AM
hydro st170
Did u find out what it is that happened?
Palethorpe01
15
Aug 18, 2015 06:09 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
