ST170 Overheating with AC on Problem Solved
Old Jul 22, 2013 | 08:44 PM
LVC-Elvis's Avatar
LVC-Elvis
Default ST170 Overheating with AC on Problem Solved
I am aware that the fan system on the ST170 is beyond questionable for many reasons.
I was suffering this problem for a few weeks, with my car continually blowing the 30A maxi fuse for the fans.
I replaced all fuses relays, complete fan housing and fans and of course the resistor pack temp sensor non of which sorted it although after all this work the fans operated temporarily until the car was moved.
Finally today I found the culprit to be the stupid harness breakout for the engine bay/cylinder head temp sensor which is clearly a Ford after thought
The harness had for sometime been fouling on the coil mounting bracket, photos below of this final solution:
Position of foul condition:
Hope this helps some people!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
dms04
Sep 11, 2015 01:57 PM
