St170 lambda and cat bracket problems. And wobbling under load please help
Old Mar 17, 2015 | 10:59 PM
Royston888's Avatar
Royston888
Default St170 lambda and cat bracket problems. And wobbling under load please help
Hi I'm Roy. New to this site and looking for help.
Proud owner of a st170
So the story starts with eml light coming on and after taking it to be read at a garage it was lambda sensor 1 so I had replaced at a cost of £155 all in. The old one had snapped! Ok replaced with a Denso sensor
So 2 days later the elm light rears it ugly yellow glow again
Take it back to the garage and he says that it is sensor 2 this time the rear one. Ok so I go to the parts shop myself and buy a Bosch lambda sensor 2 and get under car to fit it.
Find out the second sensor is rubbing on the drive shaft where the wires come out of the top. Ok. Find that the cat bracket has snapped on the cat side and and bracket side. Sorted the new bracket and having the cat side welded up.
Problem is the new sensor 2 I have bought is 15 mm longer than the original ford part. And I know from taking off the cat that fitting new bracket and putting cat back on won't give the clearance needed to fit new sensor!? So how do garages fit these sensors if they run so close to the driveshaft? Can I plug original second sensor hole and drill and weld new thread in a slightly different position ?
Plus because the garage used a Denso sensor 1 did this throw a fault with the second sensor because the second sensor is original ford part?? Is the sencond sensor damaged enough to give a fault?
Problem 2 started way before this and it goes like this..
Only under load/acceleration the is a bad wobble throughout whole car mainly above 30 mph when accelerating at any rate. All ok on braking and deacceleration. Does anyone have any experience with this? I have checked drive shafts for play and seem fine
Any advice on these problems would be great )))
Thanks Roy.
Top Bosch bottom ford part
Where rubbing on drive shaft. Wires not perished
Old Jan 23, 2016 | 05:24 PM
Nigel Sirrell's Avatar
Nigel Sirrell
Smile lambda touching driveshaft
hi,did you ever find a fix to this problem as mine is currently doing the same
Old Jan 24, 2016 | 06:59 AM
STeve's Avatar
Super Moderator
in reply to the older post 1st a lot of the time this sort of thing is caused by fitting non OE parts so things like exhausts take a slightly different line or bent brackets re the lambdas for futrure ref, re wobble nigel if this is your issue could be a warped brake disc or wheel bearing
Old Jan 24, 2016 | 01:00 PM
Ive had a few problems with my lambdas over the last few weeks. I noticed lambda to ha caught the drive shalf. I had another lambda lying about so ive put this on. The light came back on again. Fault with no 1 lambda. Ive noticed the wiring and plug is just lying around on the side of the gearbox.
Ive fitted a bracket and secured it to the bracket.
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Si B
Sep 12, 2015 06:49 AM
