Focus rs MK2 injectors into MK2 ST fitting guide
Old May 19, 2014 | 05:50 PM
steve-26's Avatar
steve-26
Default Focus rs MK2 injectors into MK2 ST fitting guide
Evening all,
Has anybody got a guide or pics for fitting RS injectors into the ST?
My car is currently running mod x with full exhaust,induction kit and inter cooler so just needing this to top it all off.
Old May 19, 2014 | 07:17 PM
RichieST's Avatar
RichieST
Don't bother. I had them on mine, and they were throwing up all sorts of error codes. When it was running ok I also noticed absolutely zero difference between them and the standard injectors.
It is a bit of a fib that Mod X is compatible with RS injectors, some cars just happen to run ok with them and some don't.
Old May 20, 2014 | 05:46 PM
steve-26's Avatar
steve-26
Oh ok cheers for reply, being as I already own a set I mite as we'll give them a go. So I'm still after a guide or pics if anyone can help.
Old May 20, 2014 | 06:43 PM
RichieST's Avatar
RichieST
Remove 8mm bolts from underneath plenum, disconnect vacuum pipe and unplug air flow meter. Remove plenum. You will then see the fuel rail. Unbolt the mountings and disconnect fuel pipe. Pull plenum out. Undo clamp holding in injectors and replace. Make sure when refitting plenum that the rubber gaskets are seated properly.
It is a bit of a fiddly job, there are a few small clips etc that are easy to loose.
manuel boeckx
13
Oct 3, 2015 02:29 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
Perfmr2
Aug 6, 2015 07:30 AM
