View Full Version : Ford Sierra / Sapphire / RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56
  1. buying a 3 door
  2. saph 4x4 track control arms
  3. problem whit sierra coss
  4. Cossie 4x4: Temp gauge is showing hotter than used to be..
  5. My New 3 Door. Setup Advise
  6. changing the timing belt
  7. new engine in saffie,now wont start!!!!help urgent please!!
  8. RS500 Lower rear spoiler
  9. setting up adjustable TCA's
  10. cossie cutting out
  11. 3 door carbon bonnet
  12. Adjustable boost?
  13. 3 DOOR RIMS
  14. RS500 intercooler question
  15. Heatwrapping downpipe on 4x4 saph cossie
  16. 3dr alloys refurb were???
  17. is this
  18. Righ, come on, whos going to own up to this
  19. difference in splitters
  20. What brake horse is ur Cosworth? Please contribute.
  21. swedish inlet manifold
  22. Can anyone help with these items please??
  23. Lots of non-cossie saph questions....
  24. Help please from Swedish Cosworth drivers
  25. help me ID these knuckles please
  26. coughin and splutterin on mates saff 4x4 what could it be?
  27. Show us some pics of your stripped interiors.
  28. what plugs and gap??
  29. Standard 3dr wheel offset??
  30. what colour?????
  31. 'O' ring-ing
  32. Headgasket
  33. What Measures Have U Tuk Securitey.
  34. WHAT TO SET C.O AT.PLEASE HELP
  35. Question on 4x4 Suspension
  36. does anyone know this car ??(G463 bvx??)
  37. Creative Carbon Heat Shield.
  38. 3 Door reving
  39. rev counter gone mad!!!
  40. somebody have the racelogic traction control?
  41. How exactly to do do a compression test??? Poss h/g gone
  42. Clutch requirments
  43. Throttle position sensor (TPS)
  44. where does your temp gauge sit
  45. 2.0 SAPH GLSi
  46. wot 2 look for
  47. PU Poly Bushes
  48. Deflex PU Bushes
  49. draper fault reader. ??
  50. speaker upgrade for the saph?
  51. Roll over jig
  52. RS500 Plenum/elbow/throttle body
  53. Rev limit
  54. A/R .63 Turbine Housing (External Wastegate)
  55. AFR 2WD Cozz
  56. ecu pics
  57. help funny noise coming mates cos,just put new HG on WTF!!!
  58. turbo???????????
  59. 3 bar map
  60. focus rs calipers on a 3dr
  61. what sort of BHP for the following...
  62. 3 door Shell
  63. 18" alloys-et40 or et35
  64. autometer gauges
  65. Brake Caliper Help?
  66. A pillar pod?
  67. more than likely allready seen
  68. Witch pods,gauges you think!!
  69. saff running problems
  70. Sapphire high revs
  71. Spec to GRA Mountune
  72. Rwd cosworth misfire/running rich????
  73. Cosworth insurance in dreaded manchester postcode?
  74. need my std FORD alarm removed
  75. need help!!!
  76. Boost setting for stage 3?
  77. wanted power steering pipe for 4x4 cossie
  78. Vernier Pulleys
  79. sapphie side skirt fitting kit
  80. 4x4 head bolts v 2wd head bolt torque?
  81. Aston Martin Caliper Info
  82. P8
  83. cpr
  84. power steering pipe
  85. 3DR Speedo cable
  86. secs monitor wanted
  87. ABS light stuck on!
  88. Gearbox Rebuild!
  89. FIRE
  90. spark motorsport REF: 0904884
  91. turbo T31/T04 RS500
  92. RS 500 engine numbers
  93. RS24 cosworth sapphire More info needed
  94. 3 door ecu
  95. XR4X4 Rear Brakes
  96. Unstable Saff
  97. air filter
  98. Tarox G88 Discs
  99. Which turbo?
  100. Hi and loads of saph cossie questions :)
  101. saff 4x4 and escos radiators are they the same??
  102. Lowered saff sitting high at front - any solutions?
  103. Turbo shaft play?
  104. Sierra Sapphire Cosworth 300 bhp setup, which is the best?
  105. F**KING MISFIRE
  106. Phase sensor
  107. do sierra cosworths have pas?
  108. tescos petrol !!!!!!!!!!!!!! ahhhhhhh!!!!!!!
  109. Speedo Dials
  110. Bottom end rebuild
  111. fuel pump
  112. Twin plate clutch on a saff cos ?
  113. standard injectors
  114. Is a blown engine worth anything?
  115. rev counter???
  116. 3 door chassis number check
  117. My Andy Fisher rebuild
  118. Help with some part numbers and what anti freeze? please....
  119. 3dr non standard colour - looking for opinions
  120. Draging rear brakes on 3dr?
  121. possible abs problem - 4x4 sapphire
  122. Cosworth insurance
  123. 2wd saff idling problems
  124. sapphire cosworth 4x4 problem
  125. eggenbergger group A block?
  126. Rouse Splitter
  127. Can anybody help me find these parts anywhere??
  128. STANDARD CAMS
  129. 4x4 cv boot keeps twisting???
  130. Grease For Propshaft
  131. Diamond Cut RS 7's with 215/40/17 tyres
  132. Insuring a 3door on classic, any good companies?
  133. ECU questions?
  134. RS500 Wheels
  135. T 38
  136. Jap vs Cossie
  137. cosworth rocker cover
  138. 2wd to 4x4 manifold change over
  139. saph problem
  140. H966 CMT WHITE 4X4 COSSY- ANY BODY KNOW IT?
  141. Heat shields
  142. Valve stem oil seals
  143. Sapphire info.
  144. 4X4 Cosworth Driveshafts.
  145. 2wd engine mounts??
  146. smoking cosworth
  147. Saph Missfire
  148. 2wd Rear anti roll bar links
  149. Finis Code for water temp sender for dash gauge
  150. Apexi AVC-R EBC anyone??
  151. removing abs system
  152. RS500 Splitter
  153. compression test results. your opinions?
  154. WHATS THE DIFFRANCE????? whats better????
  155. oil???
  156. spark plug gap
  157. saph cos idle and low rev probs. please help!
  158. my new car
  159. a little question for ECU
  160. DOES ANYBODY KNOW THIS CAR ??
  161. help!!!!just replaced headgasket,now sludge in header tank!!
  162. Battery relocation
  163. pleas please HELP!!!
  164. Dipstick
  165. with or without anti roll bar
  166. chassie no
  167. Saph problems
  168. Bilstein grA coil over on Sapphire 2 wd ?
  169. National Day 3dr Stand Anyone ?
  170. ALS on L8
  171. Original clutch Sierra 4X4 Cosworth with T34 and 1.2 bar
  172. Finis code for Saph 4x4 water pump
  173. fao koni owners
  174. Bottom end
  175. LEVEL 8 INTO 3DR.
  176. How much power for 7" rear diff?
  177. Pic's of 3dr's wanted
  178. New T3
  179. ABS Fault on 2wd Sapphire
  180. Smoking
  181. brake options for saph 4x4?
  182. Rough idle?
  183. saph suffer from electric probs? having a few probs
  184. saph horn not working
  185. Cossie Pics
  186. Moonstone 3 door, 11.200 miles. - Should I buy it?
  187. recon back calipers
  188. Please help me identify this
  189. 4x4 rear coilovers?
  190. Quick Question - With regards to Injectors and Fuel Pumps.
  191. filling up the t5-box
  192. confirm my ISCV is shafted?
  193. Sapphire cosworth colours??
  194. Brake question?
  195. t4 turbo
  196. 4x4 saff cossie brakes
  197. 4x4 Cossie idle screw
  198. Group a coil/plenum spacer questions
  199. Body panels?
  200. green injectors
  201. STEERING WHELL COWELINGS
  202. what exhuast you got on your saph?
  203. cold start crap and idle speed controlvalve
  204. wastegate leek
  205. new member
  206. Rear diff
  207. any one see a prob
  208. show me your 18"/19" wheels on your 3drs and Saf p
  209. ebays gone mad!
  210. fuel return pipe
  211. engine bay loom
  212. Rolling road and fault finding masters
  213. Is my 3 door the last produced?
  214. I WILL BE BK PLEAS HELP
  215. 18inch tyre-ARCH WORK???
  216. T38 outlet size????
  217. ECU CHIP and Mapping 430bhp
  218. 2wd cooling fault
  219. anyone had chassis rot ?
  220. 2wd manifold?
  221. Engine mounts saff 2wd yb or dohc?
  222. Rear strut braces
  223. What ECU?
  224. A few questions
  225. Help please stage 3 saff
  226. anyone know this car?
  227. Vacum Tubing
  228. 4x4 bonnet
  229. transmission fluids
  230. Itemno for coolantwater container? 3 door.
  231. group A fuel pump conecters
  232. Sapphire door rub strips
  233. Ht leads to the dizzy
  234. skyline box in a saph 4x4 cossie
  235. 3 Door Cossy Grill Mesh
  236. BEST TYRES?
  237. santa pod launching probs
  238. Anyone got some pics of the inlet plenum of a 4x4 Sapphire
  239. RS 500 No 341 on Ebay
  240. Escort cosworth engine a good choice to use in my saph???
  241. 3DR Finis Code Please
  242. ABS Help needed
  243. 18's on a 4x4
  244. Help Fitting 4x4 intercooler........
  245. Rear caliper needed
  246. Change of Colour
  247. Sierra Cosworth 4WD
  248. Engine build for 400-450 bhp
  249. sierra cosworth front bumper sagging
  250. saph 4x4 poor starting
