The RS500 intercooler fits...
Puller of the Wrench
The RS500 intercooler fits in the exact same spot as a standard 2wd one, but it has longer tubes and hangs in FRONT of the rad correct? The mounting tabs mid end tank mount up with a bracket to the rad correct?
The RS500 type intercooler is indeed in front of the rad, and about another 1/3 in height, going all the way to the top, and yes it has much longer pipes, from memory about 5"-6" long.
I am not sure how a genuine RS500 cooler is mounted, other than the through bolts that go upwards through the box section of chassis, which is the ONLY mounting on most aftermarket RS500 type ones, I fitted a piece of rubber between my rad and intercooloer because of the rocking, then tie wrapped it with a tie around the n/s outlet pipe and headlamp shell back piece to stop it moving.
