Rear arm bushes
I've recently bought a set of polybushes for my Sapph and the plan was to replace the swinging arm bushes with the proper Ford bushes because of the bearings in them, i've checked with Ford though and you cant get the full set of them anymore, does anyone know of anywhere that still does them?
Thanks, Karl
Thanks, Karl
know lambchop has a pr of the large size he might sell,and mike r might be getting them reproduced,duncan at auto unlimited did have sets at Ł150 per arm plus postage
cheeRS stu
cheeRS stu
I've been told by a few people not to do it but there may be no other option.
How does yours drive now by the way?
the bushes were shagged before so it drives loads better.mine is a bit twitchy at the front,but my steering coupling is split and perished and i have 3mm spacers on the front wheels so im putting it down to that.apart from that its great.at Ł150 per side i think i would get an adjustable rear beam.
plus the hassle of taking the arms off to have them removed/fitted.mine needed new brake pipes at the same time,and the abs clips broke.is that compomotive mo,s you have on your car?i fancy a set for my car.i have rs diamond cuts on mine,if i get them sold ill buy the compos.
Tony W
09-09-2015 12:08 PM
