ABS removal? Power steering removal
I plan to fit 3 door hubs to my Sapphire soon and I wondered about removing the ABS at the same time. If I don't connect the sensors will my braking be affected? Is there any easy way to disconnect and dump the ABS? I don't fancy re-doing my brake lines.
Also I am going to take the power steering pump, reservoir and belt off my car, remove all the hydraulic pipe work and use foam to block up the holes in the rack so that dirt can't get in. Does anybody see any reason why this will be a problem?
Thanks,
Charlie
Thanks,
Charlie
No replies. No big deal. Tonight I'm going to remove all the power steering gubbins and the belt, and will do the next event at Brands Hatch with non-power steering. I'm sure it'll be alright. I'll report back and see how I got on. I think it'll feel fine on the circuit and I don't have to do much parking ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Maybe I can get the car down to under 1,100kg.
Charlie
Charlie
Because it is only a track car I don't think the heavy steering at slow speeds will be a problem.
A couple of people have told me that a power rack should never be used as a non-power rack but nobody has given me a good reason why.
ABS I don't know about. I would prefer to remove it all but I don't know what's involved yet.
Charlie
Dr. Ickxs
15-09-2015 10:15 PM
