Exhaust hanging?
Exhaust hanging?
I had my exhaust off last night. It hangs on three rubber blocks - one at the back, two in the middle of the car and slips into the pipe that comes down from the turbo at the front.
Last time I was at Brands it was hitting the tarmc in the middle of the main straight so I was thinking of removing the rubber blocks and fixing it metal to metal so that it sits a little higher. I can see that the rubber mounting insulates the noise of the exhaust. Does it also allow the exhaust to stretch when it's hot?
If I solid mount the exhaust will it distort or crack something if there is no flex in the mountings?
Thanks all,
Charlie
Thanks all,
Charlie
It also has to account for twist in the system as the engine is loaded and unloaded.
I would just try and reshape a bit so it sits higher, then use canvas straps between exhaust and shell, mine hits at the front of the rear box over sleeping plodman's.
OK. I was planning on re-hanging it on the rubbers and adding a couple of u shape pieces to keep it in place. Mine is a straight through pipe with a small silencer box at the back.
Charlie
Charlie
