concentric and eccentric top mounts?
Rally nut
I wouldn't fit the eccentric top mount over the top strut. But what I am unsure is the stiffness of the lot (shock+top mount). Not to mention the turret. The fear is that if you drive fast enough, you can bend the shell, even with a front strut brace, isn't it ?
As with uniballs, they take out all comfort since there is no dampening by rubber. However, the good thing is. geometry stays as it should be, and inhances steering feeling/directness. concentric ones do that very well. Having excentric ones allows you to dail a some camber/caster, but your stuck with certain combo's of caster/camber so not really ideal. This is way easier to dail in.![](http://www.intraxracing.nl/UserFiles/File/Camberplates800x600/Camberplates.BMW.E30.Front.Rear.jpg)
bending shell? i'd prefer flexing, and yep that's what shells do, but not to worry about that. strenghtening can be done in various degrees to reduce that, but more or less, flexing stays.
Last edited by rinus_2005; 05-12-2008 at 05:03 PM. Reason: adjusted the link for a picture
Nice top mounts
Where can i get some ??
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
