Solid beam mounts
Passion for Fords!
well, ive only ever driven my car on solid mounts, so i cant compare with/without,
but the solid bush sits on a tiny layer of poly, and should help reduce noise, and it looks neater afterwards, as the solid mounts leave a gap between the body, which the bush filled.
im not sure if you can still get the bush i used, it was part of the deflex rear beam bush, as it came in two bits
if you look at the solid mounts only a small center section touches the body, i wasnt to keen on all the rear weight sitting on such a small surface area, in fear it may crack the leg, so the bush spreads the load over a larger area aswell
Passion for Fords!
you can see the raised center section of the solid bush here....that is the only bit that contacts the body normaly, which is gash imo
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/DSCN3054.jpg)
and you can see how the poly bush sits over it with the cut out in the center...
i didnt fancy all the rear weight being sat on that small area of the solid bush, so i did this...
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/DSCN3055.jpg)
it should reduce noise, reduce the vibration which causes the center bolt to work loose(mine never has) and fills the horrible gap
and looks like this when done,
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/DSCN3053.jpg)
the bush squashes up tight against the body, increasing the surface area of the bush
If you later add a poly diff mount, the arb will no longer fit, without cutting and welding reshaping.
I have got solid beam mounts but can't see that the poly part is going to do anything, so not going to bother myself, maybe if you are after quietness etc you might be better off with poly instead ?
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
