Which Turbo ??
dont expect to much help mate my topics just got brushed away,there should be a code on the turbo and if you take that code and ring a turbo specialist they should tell you what it is hope this helps
look for the A/R numbers on the housings, if its a t34 of some discription
it should have .48 somewere on the compressor housing and .48 or .55 or .63
in or on the exhaust housing.........it deffently DOES NOT look like any
turbocharger ive seen off a standard YB engine.
if it is a t34 or t3/4 turbo it will be fine for up to a stage 3 application
hope this helps mate
I've had a few on my Vw corrado turbo and i've
never had any issues,1 thing i did do was to fit a 360 degree
thrust bearing that i bought off eBay for 30 sqids.
I would'nt use the mega small .36 Lancia delta exhaust housing
as it'll choke the engine but will have lightning response!.
Min. i'd use is either a .48 hot side or pref. a .63 jobbie but
you'll notice some more lag compared to the smaller .48.
JK12
33
26-04-2021 12:09 PM
