T4 or T34
A wud say go for a t34 mate tbh think the t4 wud be overkill if all ya after is stage 2, t4's tend to be really laggy and tend to be used on higher spec engines .im running a t34 on a .48 housing and it spools up nice and quick
When I say ar60 I am talking compressor housing, this is std on the 4x4 sierra, 2wd had ar.42.
This would still give low down boost with lots of scope for more power, it won't give a big kick like a .63 turbine housing would, because it doesn't have the lag a .63 does to start with so there is less difference between on boost power and off boost power as it is there to start with.
A new .60 ar compressor housing fitted is around £200, I use turbocentre 01924 404112.
Russ Payne
25-09-2015 08:29 PM
