Copper Turbo Down Pipe Gasket
I never knew anyone made these, but easy enough to make yourself if you want some, and for only a coulpe of £'s, just need a piece of wood and some drill bits.
Bollocks for some odd reason I read DRAIN and not DOWN, and thought you meant the drain tube , sorry.
I'm not aware of anyone making any for this area, but FERRIDAY ENGINEERING would know if anyone does.
Have a careful look at your downpipe flange to see if it has a little ridge where the flare is, as this can cause this, just a little time with a file soon sorts it, best to take pipe off though, failing that put some firegum on it.
jus smooth off the high spots with a file......never seen a gasket for the turbo/downpipe flages lol. i also dont think copper would be the best bet either
as it work hardens an caracks then falls to bits inless your gonna pull it
out and anneal it every so often.
Matt Baxter
16-09-2015 08:30 PM
AndrewStrang
01-09-2015 11:16 AM
