- Buying a FRST
- has anyone got or heard of the modified t2 return pipe?
- Changed the lights again
- morettes
- How hard to fit MK1 1600 xflow into early mk3 van? or 1.1mod
- Fiesta Turbo with a T3?
- Oil Change on FRST
- mudflaps
- Mk3 Smoked Front Indicators
- turbo converstion
- what is needed for 1.7 puma into mk5 fez
- tyre pressure?
- mk3 with rs turbo geabox
- wot car should i use
- What radiator??
- Anyone fitted 15's to their MK3?
- XR2i Idle Problem (still happening)
- RS SUPER 1600 FIESTA RALLY CAR
- a very rare fiesta rs item here on ebay! green strips.
- random starting
- Selling an RS....
- anyone know how much a si kit 4 a fiesta mk 3 cost?
- osf, nsf wings
- Where best to get FRST uprated engine mounts?
- fiesta si-turbo
- fiesta rs turbo door/rear quarter spraying - ITS BACK 30/4
- mk4 fiesta colour code
- Strut Brace
- Pic request: GFJ with RS2k wheels
- electric window switches
- mk3 fiesta 1.6 16v.how much bhp should it have for standard.
- Keys on an M reg 1.4 Fiesta si
- living with an frst
- cossie 4pots
- Torque settings
- clear lights
- dash conversion on frst
- Mirrors
- Help!!!! Fiesta Turbo
- quick rack from quaife
- 2.0 zetec in a mk4
- Adding an Electrical Oil Temp Gauge? Sensors?
- mk4 16v to 8v turbo conversion - or rs2k
- any cheap brake upgrade's from scrap yard cars?
- Engine Oil
- Escort/Fiesta CVH Engines, N/A AND tURBO'ED any differeces?
- zetec turbo questions
- Best ways to keep my FRST cool
- 130PS ECU
- Rear Dampers
- fiestaturbo.com down??
- Fiesta Carbs
- Springs on Fiesta
- engine transplant mk4/5
- My Fiesta Update
- experiences with hybrid T2
- No spark
- EFI Idle problem ( RS TURBO )
- airtec rad's
- Opinions and Pictures of Boot Decals Needed!
- 4wd cossie front brakes
- Fiesta RST Buying Tips...
- boot decal
- FIESTA TURBO NOT HOLDING BOOST??????
- Zetec S Owners - Help
- Where to find an efi frst fuel pump electrical plug
- Fiesta MK6 Dash
- kent cams in a zetec engine
- cossie fuel pump in tank
- fiesta rs turbo driveshafts
- The usual turbo question...
- Gearboxes and ratios....
- FRST bottom arms
- ofac 195 chip choice
- Clutch slave cylinder
- Bigger Engine For Mk3 Fiesta 1.1
- Rarest colour?
- silver top zetec cams what will fit what?????
- ERST engin into a XR2I
- What actuator?? T2 turbo
- fiesta rst fan switch plug?
- EFI Head, XR3i the same as Turbo?
- just been told bad news
- Shock Absorbers
- Boost Problem
- spotted frst in plymouth, devon.
- efi idle
- non-starter
- rocker covers
- fiesta xr2 uprated brakes?
- Maybe should of posted in this room.......
- Fiesta turbo parts
- fiesta rs turbo bumper & side mouldings
- What to look out for?
- any pic's of chroem engine bay on fiesta rs turbo
- Need Help
- which colour hoses's?????
- Power Steering in a RST
- Zetec S Spark Plug Gap (2000/W)
- Fiesta turbo arches and skirts wanted
- Fiesta Turbo Project
- miles to the gallon?????
- How much boost??
- Boot Decal
- chrome for engine bay
- Zetec s calipers what fits and what dont HELP
- how much is a set of green side mouldings worth?
- Mk 5 fiesta heater motor
- XR2i 1.8 16v vs RS1800
- Help with melting issue for my friend
- My Fiesta
- looking for some fiesta sensors
- Chips
- efi conversion and T3 questions
- efi inlet on frst
- firing order
- MK3 Fiesta Rev Counter
- fiesta si turbo
- mk1 fiesta 1.1 pop+
- MAS sensor
- WANTED RS1800 Gearbox
- ACT???
- heads
- XR2i Dash
- what handbrake cable have people used for RS2k disc conversi
- Camshafts
- Rover Manifold For Zetec Turbo
- chip or no chip....
- Electric Mirrors?
- frst valve stem seals
- beige injectors
- mk2 XR2 pics
- Was it you? - Blue 2i 16v/RS1800 - Glasgow
- RS Turbo Pop Out Windows
- HELP!!!!!!
- Car jurking and spluttering
- I now have a 2i
- Swapping my wheels?
- details about h288 hpy
- Fiesta TDCi!!
- IB5 gearbox
- doin a few jobs to my fiesta turbo
- black wheels
- M reg RS1800
- check out my MK5 RSi
- what next???? mk3
- XR2I to RST engine swap
- thinking of a rs turbo??????
- mk3 fiesta cam question
- restoration stage 2 on j660cfu
- mk6 fiesta carbon bonnets-pics enclosed
- T3 causing starter to fail due to heat
- rare drivers side brand new green side strip on ebay!
- MK5 - 2.0 Zetec Research
- my mint mk1
- hks blowoff valves?????
- Wiring Diagram
- Wiring Diagram
- ENGINE BUILD
- price on rs1800, lookin to buy 1
- wiring diagram
- CVH with twin carbs - timing?
- whats the best chip for me
- nor been done in a while,rs turbo pics
- Cam Question - CVH 31 Vs CVH 35
- HELP NEEDED WITH CHANGING THE SUMP GASKET
- HELP Recaroe Seats in Mark 5 Zetec s
- how much is a mint mk1 worth?
- Fiesta xr2i to rs turbo! Help and info needed plz!!
- Fiesta turbo in kit car questions
- 1.25 Zetec 4000rpm Flat Spot
- imperial blue fiesta
- track day noise limits
- Is it possible to tune mk4 fiesta 1.3?
- mk6 fiesta offset question
- rst fuelling system
- mk1 fiesta pics
- can someone tell me the colour
- looking at a fiesta rs1800
- van
- Anyone done a Fiesta zetec s turbo??
- I have a problem with running my fiesta rst ar cold
- passenger green doorstrip wanted!
- burton power mondust fiesta on ebay
- Fiesta Wiring Loom and parts needed
- Fiesta zetec s
- my genuine FRST exhaust cleaned! some pictures for you.
- Roof question
- Brake Up Grades
- fuel pump
- handbrake problems
- can escort cosworth calipers fit
- Fiesta RS1800 gearbox ratios
- Fiesta Zetec S Engine Conversion
- 1.25 Zetec beating a 1.4 Zetec?
- My MK4 Project
- What to look for when buying an XR2i
- Idle Problems (again)
- FRST Oil leak
- Fiesta dashboard Problem
- Fiesta Zetec S ...
- how much are my brand new green FRST door mouldings worth?
- VIN plate for 1991 Fiesta RS Turbo
- looking for info on roller Hyd Lifters
- Rs Turbo gearbox suggestions
- My Fird Fiesta Si 1.6
- dash +seats frm fiesta rst into mark2 xr2?
- Puma Gear linkage
- anyone wanna do a wheel swap
- chip for my frst
- mk3 door catch adjustment
- Header tank
- Oil Cap
- throttle bodies or cams ??
- efi head info needed
- MK3 offset
- can you give me fords FRST green side strip prices? by 6pm!
- Getting Parts...
- Xr2i database- 8v and 16v
- s.i. exhaust
- YELLOW FORD FIESTA RS TURBO WITH A FORD RS COSWORTH ENGINE
- Low Mile XR2i
- Pics of Mk3 Fiestas with Mudflaps on.
- Fiesta Pats( security/imobilsers)
- EFI idle
- electrical problem
- are the rub strips on a mk6 fiesta 56 just stuck on or clips
- parcel shelf the same or not the same
- 2.0 zetec power figures
- where can i get a standard frst exhaust from PRETTY PLEASE?
- EsCos Rims on an RS1800?
- Desperately need map sensor
- MK3/3.5 Racks
- 15's on a mk3
- Nurburgring April 2007
- road trip to spain july 2007
- Exhaust Manifold Question
- act gauge
- New n/s/r 1/4 panel required
- imobiliser on mk3 fiesta
- Picture Request and Engine Swap Advice?
- For the mk3 Boys and Girls
- is the xr2i inlet different to the rst
- looking for a fiesta turbo
- f#@king car thiefs
- FIESTA RST INJECTORS
- Is it hard .........
- FIESTA RS TURBO FOR SALE £1250 ON TURBOSPORTS SITE
- Some Pics Of My Si & Friends 56k make a brew
- Wishbone bushes
