RS Turbo Pop Out Windows
Will these fit straight on to a 2i? I know I would need the glas, rubbers and brackets but are all the bolt holes already in place for the brackets and will the rubbers fit directly on without any messing about?
You'll need to cut the C pillar trim panel (the section to cut is marked) for the widow handle. The B pillars will require a threaded insert fitting to bolt the hinge in place. With a rinut gun my brother and I converted my S2 to opening rear windows in 45mins
Matt Baxter
16-09-2015 08:30 PM
