FRST bottom arms
FRST bottom arms
Right going to get my self some new bottom arms to stop my fiesta pulling its self everywhere, has anybody any experiance of the deflex or zoo motorsport items any knowledge would be good. THANKS ALL
Just buy the powerflex bushes for the anti roll bar and the bottom arms - adjustable bottoms arms arn't designed for loads of miles on the road as the cylinder bearing gets crap in it and fooks up, these are for track/strip use etc, go with the bushes that will sort your problem.
deflex have stopped trading but i have no doubt they will be back under a different name.
Deflex are rubbish pal! They lasted me less than 400 miles!!!!
Im getting some lower arms next week and using the left over Powerflex bushes from my kit.
i nearly went for those, so glad i didn't!
i've done about 4500 miles on my rose jointed ones (all through winter as well) no discernable wear so far
i use ian howells camber adjustable lower arms with standard bushes tho i'm going to upgrade these to powerflex shortly.
these allow the geometery to be reset after fitting aftermarket suspension.
Must say i'm well impressed with them, the change in grip levels and general handling is immense. They allow me to run maximum -ve camber within ford tolerances and keep the contact patch at it's max.
You need a quality place that knows what they're doing to set them up tho.
SMILER258
28-09-2015 09:04 AM
Fudgey
17-09-2015 01:06 PM
