No spark
No spark
Hi my ZVH converted fiesta has suddenly died on me and iseant producing a spark on any plugs.I pulled plugs and seemed fine so then got a multi meter and checked loom plug connecting to coilpack to check voltage and everything is fine here also so i then pulled 1 lead at a time and tried for voltage inside lead while turning engine and no voltage here so basically what im asking is is it likely to be the coilpack or has anyone ever experienced all 4 leads fucking up in 1 go?? And also anything else that could cause no spark apart from this?
CheeRS
CheeRS
Originally Posted by y4n
hi snedboy check the crank position sensor this can cause no spark if knackered
CheeRS
Originally Posted by richard_syko
Front of the engine on the gear box side. What loom/ECU are you running?
The coilpack will have 12 volds regardless of whether the CPS is working. The quick way of checking the CPS is by putting a Noid light on one of the injector plugs. If it flashes your CPS is working.
i had this problem, i got ma mate out who is an auto electrician and he had a look for 2 minutes and saw that i had mixed up the CPS sensor with the temprature sensor, the plugs on the ends look just the same!!! try this!!
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
