cossie 4pots
Originally Posted by AGAR-COSWORTH
No, 2wd brakes only fit Escort RST's. 4wd brakes are what fits onto fiestas.
will the 4x4 brakes fit straight on or do you need mounting brackets?
currently using wilwood four pots wioth 300mm discs but i need to drop down to 280mm disc so i can use 15" wheels for drag..
thanks in advance
sean
Redumbdancy
thanks in advance
sean
No mounting brackets are required as the hub holes match up with the calliper holes perfectly. However you will required to use either spacers or washers the space the caliper away from the hub slightly. You will also need to drill the hub holes out IIRC to accept a bigger bolt.
Best PM H196 JNE on here as im sure he knows.
Hope this helps you.
thanks in advance
sean
thanks for the info
thats what my m8 told me but i just wanted to make sure
i have just purchased a set of recon 4x4 calipers and new grooved discs
Russ Payne
25-09-2015 08:29 PM
