View Full Version : Fiesta RS1800/RS Turbo
Pages :
10]
11
12
13
14
- cam and boost
- Oil Breather Seperator
- New Lightweight Racing Seats
- Installing an aftermarkter REVcounter???
- FIESTA SI WITH TURBO, PROBLEMS please help needed
- de-ABS-ing a Fiesta turbo
- Thank God I got off lightly!
- Ford Finis Codes.....
- Smoking when cold
- rev limiter
- mondeo/esc rims pics plz
- Disaster, a day before my RR
- I didn't know....
- My Crossflow Engine
- fiesta si with turbo engine in need of help
- My Xr2i - Back To Her Former Glory...
- Oil coolers on Fiesta....
- corbeau seats into rst.help!!!!!!
- injector advice
- heres some pics of my frst wot do you think??
- ashley exhausts
- Show us your FRST's
- wheel colour??
- big end bearings
- Cheep white dials
- 2.1 in frst
- recaro seats wanted
- This months FF
- Recaro seats
- new fuel pump (TIS)
- Pics of oil seperator fittings?
- cosworth engine in a fiesta
- Ford Fiesta clutch
- Exhaust
- Tuning the 1.6 8v CVH
- Cossie 4pot calipers
- mk5 with fezza lump need some advice please
- rear disc convershion
- Boost limit
- Bonnet Vent Fixing
- xr2i and frst cam?
- info on steel bottom end
- Underside of an RS1800
- Some advice needed on a fiesta st
- Pic request!!!!!!
- i replaced the engine mount today ......
- temperature gauge on dash
- turbo oil seals???
- Rear disc help
- how many miles to a full si tank??
- cossy wheels wont fit onto the hub????
- mk3 loom wanted *URGENTLY*
- Forum Newbie and Si Owner
- cvh34 cam or cvh35 cam?
- FOA "jive"
- fiesta t2
- cold start prob frst
- RS turbo fiesta alloys for sale
- Anybody seen a RS1800 make it's claimed stock output?
- Oil and water gaskets for turbo
- Help needed to start frst
- Wanted XR2 MK2 hoses
- yet more probs with the rst
- Which Camshaft?
- where abouts is . ....
- uprated breather,high idle
- fiesta zetec s rear axle
- Engine Modifying
- mk2 2.0 zvh turbo fezzie all painted :)
- ZSOC Meeting Sunday *Pics*
- She had a good run out today
- raising the power.............
- recaro interior colour
- fooking freezin
- help needed for colour of frst
- IN THE REALISTIC WORLD, WHATS BETTER CVH OR ZETEC TURBO???
- EAGLE steel rods for Zetec Turbos???????
- standard fuel pressure
- ANY 1 GOT A CENTRE CAP 4 A STANDARD TURBO ALLOY
- headgasket
- si clutch Q????
- 200bhp from a frst engine...
- rs turbo piston rings
- Mk5 1.3 endura tuning advice
- Heated front screen...
- Fiesta MK6, 4x4, Focus RS Engine
- gearbox making funny noise
- Last nights Breakdown :(
- getting wiring sorted!!
- cossie brakes on fiesta rs turbo
- heater matrix
- focus alloy wheells on fiesta rs turbo
- Tourmaline Green RS1800
- mk2 xr2 chassis rail
- Ashley 4-2-1 Branch Manifolds
- fiesta mk2 panique wide arch kit
- WATER TEMP GAUGE????
- rear / full roll cage
- quick question
- opinions
- accralites
- cheap insurance for a fiesta rs turbo
- Supersport
- Loud hissing noise from 1995 mk3 fiesta
- Fittibg a Cvh in Mk1 Fez?????
- Fitting WATER temperature gauge
- Seats
- Thinkin bout buyin a Fiesta zetec-s
- wiring nearly caught on fire!!!!
- tut!!!
- Fiesta RS1800 / ZETEC Exhaust options??
- Mfi block to EFi...
- gauges
- i need a new gearbox
- kent cam or pipercam
- I thought I'd show my motor off
- Loom Gurus - HELP ME!!
- rollcage
- Angel Eyes
- cossie wheels on the mark 6 fiesta
- Any good?
- big valve head
- Rebuilt cost of a FRST Bottom end
- wot is the correct oil for frst????
- If I turbo'd
- hello all, pics of my mk2 fiesta, zvh turbo
- New Guy with 1.4 Si
- just wondering
- Anyone know the where abouts of..
- wot engine oil should i be using
- fiesta brakes problem
- im new to the forum and my xr2i
- carb airbox
- oil check on frst
- Can someone help????
- compression test.....
- Psg wide arch kit
- cossie style alloys wont fit?
- strut braces
- rear cluster pic requst
- blue smoke
- Fiesta mk3 XR2I
- drifference between the frst and xr2i heads
- Problew Starting When Cold ???????????
- IS SHE STILL ALIVE??
- what a bargain i grabbed!
- Alloys
- Problem freezing plug
- lights
- turbo on ebay
- what ecu?
- FAO anyone with a black leather fiesta steering wheel
- rst breaks
- Ford Fiesta 1.1 J-Reg
- merry xmas
- wheels?
- heater matrix?
- heres a pic of my fiesta turbo
- cossie turbo onto a erst manifold
- help! door needed
- Pic Request
- Is the AMP powerful enough for the SUB? Inverting SUBs??????
- FRST Flywheel needed
- location, location
- Suspension??
- Which fuel system???
- mondeo alloys swap? escort gti alloys?
- Fiesta 1.25 Zetec - what engine to swap in?
- fueling adjustment
- The body kit on my RS1800
- T3 downpipe
- engine swap?
- How can you tell if a turbos on its way out???
- 1st Gear Problems with RS1800
- ford fiesta rs turbo 1.8 conversion
- AUDI 1.8 TURBO INJECTORS?????
- Engine temp sensor Q
- zetec in mk2 xr2
- Mk3 Fiesta's
- Performance!!!!
- OIL CAP BLOWIN OFF!!!
- 2wd cossie 4 pots on a fez (work in progress)
- mk 1 fiesta supersport
- turismo splitters, eyebrows etc
- my RST
- stage 1 superchip... problems!!!
- RS1800 would like a bit more power and general help
- Fiesta XR2i 16v ECU Location....
- 2.0 16v Converstions....
- cossie fuel pump
- 4 x 4
- More fooking problems
- fuel pump
- Fiesta Fuel rail question - Help pls ;)
- changing engine?
- help, frst overheating!!!
- 140bhp cvh
- Rear discs for mk1 and mk2 on ebay
- US member with some questions about the Fiesta RS manifold
- My lil baby fez
- hi all new blood
- Wiring....
- My Mk2 Fiesta On The Roller's At EA
- Fuel pump FRST
- Gear Selector Linkage & Rods....
- vin number
- RS 1800 owners!
- Engine mounts?
- heater matrix
- turbo and manifold removal
- mondeo alloys?
- the best breake upgrade for a fezza xr2i?
- Hoses
- 60mm?
- anyone wanna swap wheels?!
- Festa boot build
- Rebuilt FRST Engine
- 195 chip
- What the fcuk is it lol
- rs 1800 zausts
- FRST problem...
- stage 2
- Probs Starting!!
- Anyone got there fiesta RS in for repair at HAVERHILL?
- cylinder head
- Low Level Fuel Light...
- 4 pot cossie brakes on fiesta rs1800
- emissions
- Best intercooler
- FRST
- fitting beige injectors
- Performance Cams?
- mondeo rims!
- 16v zetec to ofab
- Coolant
- mk.2 xr2
- WANT MORE POWER!!
- FRST temp guage prob.
- mk1 1.1l fiesta conversion
- milage
- mk1 fez turbo
- rear lights dont work ! HELP NEEDED ASAP
- my frst
- Gearbox Options...
- wheels
- anyone gota mark 4 boot on the mk3?
- Need some help!!!!
- So what do you own......?
- is anyone else having probs with fiestaturbo.com
- Fiesta probz
