quick question
Originally Posted by turtleturbo
Hi,
Quick question Schock asorbers/springs and frontBrakes of a FRST, are they the same as ERST of XR2I?
disc and pads and calipers are the same as xr2i, you will find the ERST ones are the same too.
Originally Posted by Oranoco
ERST and FRST brake discs are not the same and if you want to be extra picky the pad material is slightly different between the FRST and the 2i
as for pads, only if ya getting them from fords or racing pads etc, off the shelf stuff like mintex, unipart etc list same part numbers for both cars
yes mate, xr2i shocks will fit the FRST but from standard/new the shocks are different, but if you but unipart etc they list the same part for the 2i and rs so will make no odds at all.
dont start Oranoco
dont start Oranoco
FRST suspension differs from XR2i by the following:
Front dampers have the same body but stiffer damping.
Front springs the same.
Front ball joints offset 10mm
Rear spring/dampers unique, as said above 25mm shorter
Rear axle has an additional stabiliser (with brackets welded to axle)
the anit roll bar (stabiliser) you on about is the same on 2i's that have them, same as rs1800
and if ya wanna be really picky (fuck me i sound like you Oranoco
) the front ball join is 10mm longer and 10mm set back and is the FRST is the only fiesta that uses them ( or should) but if you lower the car a lot you will scrub out the inside of ya tyres even if ya tracking is spot on, dont give a fuck what anyone says it DOES do it, as ive been there, dont that and got the t shirt.if you lower it more than about 30mm you wanna use a different ball joints, ive lowered my car about 50/60 mm (on avos coilovers) and i use a different ball joint and since fitting the different ones about 6 years ago i have never had a problem with tyres scrubbing out
if you buy after market stuff, spax etc the ones they list for a MK3 fiesta covers all range's from 1.1 to frst and are the same, the different shocks are only the standard gen ford items mate, which if ya dont go for, then it dont matter
SMILER258
Sep 28, 2015 09:04 AM
