Ford Finis Codes.....
Most of us should know but Ford use "finis codes" for their part numbers which is basically a 7 digit numerical code.... It does makes things alot easier when ordering parts for older cars if you have a "finis code" as it makes the Ford partsmans job easier and should in theory give us the right part....
So if anyone has any "finis codes" please PM me with them and what the part is and i'll add it to the list below that i've started...
Steve
CVH oil filter - 1070523
XR2i and RS1800 oil filter - 1066071
RS Turbo exhaust manifold gasket - 1023231
CVH rocker cover gasket - 1651775
RS Turbo head gasket - 1658584/6918549 (1 maybe an old number)
EGR removal kit for Zetec - 6732263 and 1008597 (4 of each needed)
FRST/XR2i lower arms - 1054986/1054987
RS Turbo HT lead set - 1202518
Fiesta RS Turbo cyl head- 1029256
Steve
few bits that ive bought from ford. all for a fiesta rs turbo
5024195 - wheel bearing kit - 39.90
6775553 - heater matrix - 57.80
5020405 - fuel filter - 18.09 +vat
1503882 (2) 6054981 - fuel filter copper washes 27p each+
1004005 - header tank - 22.63
got loads more, but i didnt write down what they actually were, lol
1610085 - CVH Oil Filler Cap £2.10 + VAT
6789185 - Mondeo wheel studs (5mm longer than FRST) £0.60 each
7257202 - Steering RackUV Joint £16.37+VAT
1661562 - Steering Rack Gaiter £14.80+VAT
1073803 - CV Boot Kit £16.32+VAT
4410264 - Focus ST170 Brake Disc £53.80+VAT each
6587794 - Fiesta RS Turbo boot sticker £11+VAT
Manual Clutch Adjust Parts
7304014 - PEDAL_CLUTCH £22.66 + VAT
7346848 - PAWL_QUADRANT £2.05 +VAT
7304020 - ROD ASSY_CLUTCH £2.39+VAT
7304018 - RETAINER_CLUTCH £11.56+VAT
7304016 - SPRING_CLUTCH £2.96+VAT
7304016 - PLUG £0.41 + VAT
7021871 - BUSH_BRAKE £1.35+VAT
3415236 - NUT HEX £0.55+VAT
FRST Pick up pipe gasket - 6169337
FRST Oil pressure switch - 6716335
FRST ISCV 6464929
FRST HT Leads (Come seperate!) 6592244 £9.65 6592245 £8.82 6592246 £8.82 6592247 £7.22
FRST Crank position sensor - 6859702
FRST IAT 1659273 £23
FRST Inlet Studs - 6185201
FRST Inlet Nuts - 6076340
FRST Air Charge Temperature 1659273
FRST Engine Coolant Temperature 681042
FRST Tank = 6987577
FRST Filler Pipe = 6744379
FRST Edis Module - 6641381
FRST Head gasket - 1658584
FRST Head Bolts - 6088344
FRST Idle speed control valve gasket - 6561838
FRST inlet manifold gasket - 6188592
FRST Rocker cover gasket - 1651775
FRST Exhaust manifold gasket - 6591017
FRST Top rad hose 6663239
FRST Steering rack 5026747
FRST Plug lead bracket 1661721
XR2i Map Sensor 1648137
Escort RS Turbo oil feed pipe (braided hose with threaded fittings) 1647776 £52.05
Escort RS Turbo oil return elbow pipe 1640090 £34.86
Escort rs turbo Manifold Bolts 1549071 £0.34
Escort rs turbo Manifold Washers 1465430 £0.07
Zetec Inlet to Sandwich Plate 6669767 - £7 ish
Zetec Sandwich Plate to Head 6789153 - £18 ish
Zetec Exhaust Manifold Gasket 1044867 - £6 ish
Zetec Sump Gasket 7008824 £10 ish
Zetec Starter heat shield 1654781
Zetec egr Blanking plugs 6732263
Zetec egr Copper Washers 1008597
Zetec Inlet manifold 6787654
Zetec Underpiston oil jets 1663919 £2.80+vat
Zetec bolts for the above 1665180 £0.60+vat
Zetec Cambelt Kit 1112530 £88.30+vat
Zetec oil pump 1663901 £104.80+vat
Zetec water pump 1317021 £53.09+vat
Zetec cam cover gasket 1663394 £8.20+vat
Zetec head gasket 6847748 £21.78+vat
Zetec Focus RS Spark Plugs 1202935 £5.95+vat
Zetec 1600/1800 Sump 7008816
Zetec Rear engine Mount 1014050
Zetec Clutch Cable 7119320
Zetec Alternator Cable 6706118 (si 16v)
Zetec Alternator Cable 6757249 (rs1800)
header tank - 1004005 - 22.63 +
header tank cap -7267969 - 4.37 +
Brakes & Clutch
Adjustable clutch pedal 1029012 £10.78
Quadrant 1029013 £7.23
Brake & Clutch Pedal bushes 7021871 37p each
Brake Pedal Switch 6089985 £5.34
Brake Pedal Switch Retainer 6089984 38p
Main Shaft End Clips 1583756 28p each.
Rubber Pedal Pads 6168375 £1.79 each
Main Shaft 7065813 £5.05
Clutch Pedal Spacer 1654168 42p
Brake Pedal Spacer/Spring 6598313 £1.05
Brake Resovoir (NON ABS) 6942055
Brake Resovoir (ABS) 6942056
Suspension
Front ARB 16mm left hand drive = 6868842
Front ARB Droplinks 1661237
Front ARB Retainer 6788739
Front ARB BUshes 7102392
Rear ARB 6552167
Bodywork Trim & Windows
Rear window pop out handle 6699750 £10.74
Front Heated Windscreen F7108842 £157.16
Windscreen Rubber F6985872 £36.00
MK4 RH light panel - 1043987
MK4 Rear Centre panel - 1094981
MK4 LH light panel - 1043988
Headlamp Protectors - 5025597 £37 ish
MK4 left hand heater vent midnight balc 1109411 £14.58
MK4 Right hand heater vent midnight balc 1109410 £14.58
MK4 centre heater vent 1056733 £88.28
Doorcard winder hole blanking cap 1656119
Mk3 Petrol Cap replacement Panal 6185148
Mondeo Alloy Center Caps 5052092
Small Ford badge 7305842
Flush Interior Mirror trim RH D/E (finis 7193577)
Flush Interior Mirror trim LH GB (finis 7193578)
MK4 rear Wash Jet 1044285
Sticker - Headlamp Levelling 6752555
Sticker - Asbestos 1652835
FRST Gearnob - 6567049
Zetec S Rear beam 1105239
Sunroof hinges - 6175370
Sunroof screws - 1632654
Focus RS Badge 1135344
heater matrix - 6775553 - 49.19 +
wiper blade 1148887 - 5.08 +
wiper blade 1148898 - 5.87 +
wiper arm 6175584 - 17.26 each +
Electrical
Heated front windscreen switch 6180166
Red Pats Key 1063687
FRST ISCV 6464929
FRST Tank = 6987577
Brakes & Clutch
Suspension
Rear ARB 6552167
Electrical
6166108 (sump gasket) gasket-oil pan £16.73 +vat £19.66
6149337 fuel pump relay £7.55 +vat £8.87
6200758 (HT lead separator - the plastic part) seperator-wire £1.95 +vat £2.29
1661721 bracket (metal bit for HT lead separator) £4.11 +vat £4.83
6561838 idle speed control valve gasket £1.05 +vat £1.23
Fiesta rs turbo green side mouldings
www.fordpartsuk.com
Fiesta-Front Wing Moulding LH (Grey/Green)
Part Number: 1661639(QTY1)
Retail Price: £11.27
You Pay: £10.14
Fiesta-Door Moulding RH (Grey/Green)
Part Number: 1661791(QTY1)
Retail Price: £19.37
You Pay: £17.43
Fiesta-Rear Quarter Moulding RH (Grey/Green)
Part Number: 1661768(QTY1)
Retail Price: £14.77
You Pay: £13.29
Fiesta-Rear Quarter Moulding LH (Grey/Green)
Part Number: 1661767(QTY1)
You Pay: £13.29
Fiesta-Front & Rear Bumper Mouldings (Green)
Part Number: 6553428(QTY2)
Retail Price: £11.40each
You Pay: £10.26each
Rare part
CG Ford, Carlisle : 01228 810600 Fiesta front wing moulding RH (green/grey)
part number: 1661638 (QTY1)
Price: £10.89 + vat
www.fordpartsuk.com
You Pay: £10.14
You Pay: £17.43
You Pay: £13.29
You Pay: £13.29
You Pay: £10.26each
Rare part
Price: £10.89 + vat
finis codes
Fiesta RS Turbo Parts:
Front dampers 1 133 915
Rear dampers: 1 133 934
rear brake pump: 6 187 602
rear brake shoe kit: 6 183 877
rear brake regelation: 6 187 604
chassis:
full rear panel: 6 637 284
full left rear panel: 1 659 559
full right rear panel: 1 659 558
left front fender: 6 585 194
right front fender: 6 585 192
full front panel: 7 049 560
left sill: 6 185 145
right sill: 6 185 144
wiper panel: 6 169 015
battery tray: 1 014 110
battery tray suport: 6 835 682
chassis:
Redumbdancy
Hi there,
Can anyone give me the part numbers/finis codes (and price if possible) of the following items:
FRST Parts:
Front ARB bracket bolts
Rear ARB bracket bolts
Front Crossmember bolts
Mk3.5 Parts:
B-pillar trim Left
B-pillar trim Right
Many thanks
FRST Parts:
Mk3.5 Parts:
B-pillar trim Left
B-pillar trim Right
Many thanks
rs1800/xr2i 16v
all prices are retail as i get them cost coz i work there
timing belt kit - 1112530 £68.27
oil filter - 1119421 £5.71
cam cover gasket - 1663394 £9.59
sparky plugs - 1233897 £6.45 ea
fiesta rs parts
7138825 rs1800 radiator
7313237 rad top hose
1000366 rad lower hose
690887 over flow hose
1505594 nylon thread nut(for balljoint pinch bolt)
6080625 ball joint pinch bolt.
part numbers???
Hi
I am looking for part number for the FRST kit.
front archies
rear archies
skirts
I know it come with different codes depending on colour, I ideally want the codes for mercury grey, but any would do as will be getting painted with the shell.
front archies
rear archies
skirts
6166108 (sump gasket) gasket-oil NY Escort pan £16.73 +vat £19.66
6149337 fuel pump NY Escorts relay £7.55 +vat £8.87
6200758 (HT lead NY Asian Escorts separator - the plastic part) seperator-wire £1.95 +vat £2.29
6561838 idle speed control NY Asian Escort valve gasket £1.05 +vat £1.23
Fiesta Zetec S door hinge assembly 4154235.
Edit - Apologies, just noticed this is for RS 1800s and RS Turbos (oh well at least i got the Fiesta bit right).
COS i'm WORTH it
well i just fell like i got bummed by my local dealer.... anyho
finis 6617379 - hard pipe hose from crank case breather to airbox £39.46
finis 6617381 - crankcase breather vaklve assembly £7.08
finis 6617380 - connecting hose for crank case breather £6.82
finis 1661014 - crankcase breather £26.18
finis 6617376 - hard pipe from inlet to breather, a staggering £71.99 for a 3 inch pipe!!!
www.fordpartsuk.com
You Pay: £10.14
You Pay: £17.43
You Pay: £13.29
You Pay: £13.29
You Pay: £10.26each
Rare part
Price: £10.89 + vat
www.fordpartsuk.com
You Pay: £10.14
You Pay: £17.43
You Pay: £13.29
You Pay: £13.29
You Pay: £10.26each
Rare part
Price: £10.89 + vat
borboyous
22-08-2015 11:17 AM
