yet more probs with the rst
just took my fiesta rst out for a drive and as i was going down the road my heaters cut out and my fan was not working, also the front fogs would not come on, got her home to check all the fuses but they were fine, its my first rst and ive had nothin but probs with it but there has been nothin major so far,, can anybody help as its spending more time in the garage than on the road cheers
HI MATE. YOUVE GOT THE CLASSIC PROBLEM THAT I GET FROM TIME TO TIME.
BEHIND YOUR FUSE BOX, WHERE THE ACTUAL RELAYS SIT, THERES A GREEN RELAY WHICH IS PRONE TO BURN UP A BIT FROM TIME TO TIME.
THIS RELAY CONTROLS THE FAN, FOG LAMPS AND HEATER.
JUST UNDO THE TWO FUSE BOX SCREWS UNDER THE FUSE BOX PLASTIC COVER, PUSH THE BOX INTO THE FOOTWELL AND REPLACE THE RELAY. TEN MINUTE JOB.
HOPE THIS SOLVES THE PROBLEM.
THANKS FOR THE FEEDBACK MATE, IM ALWAYS CLEANING OR LOOKING AT THE WAY THINGS WORK ON MY FRST, IVE HAD IT 8 YEARS SO I SORT OF KNOW A BIT ABOUT THE PROBLEMS
ANY OTHER PROBS U GET (HOPEFULLY NOT) THEN IM ALWAYS LOOKING AT THE SITE FROM TIME TO TIME, TO HELP PEEPS OUT.
GOODLUCK ANYWAY GEEZ
07-10-2015 12:56 PM
