My Crossflow Engine
I am thinking about selling my crossflow engine how much do you think i will get for it it has done 3000 miles from new
Here is the spec
Engine: 1700 X/Flow stage 2 unleaded.
Bore +090 1686cc Fiesta.
Stoke standard.
Main bearings standard L/c material.
Big end bearings standard L/c material.
Thrust washer’s standard.
Crank standard linished fully balanced.
Flywheel balanced and machined.
Rods balanced end to end.
Pistons Hepolite balanced.
Camshaft piper BP285.
Timing chain morse H/D.
Tensioner pad and snail new.
Corplugs new.
XR2 sump and scavenger pipe fiesta.
Oil pump High pressure new.
Cam profile.
Power increase 18 to 20 bhp.
Duration inlet / exhaust 292 degrees.
Valve lift .430 thou 10.92mm in/ex.
Timing open/close 38-74 74-38.
Full lift at top dead centre 108 degrees.
Valve clearance 14thou .35mm inlet and exhaust.
Cylinder head fully flowed with three valve seats and mexico
inlet and exhaust valves double 285 springs.
![](https://img.photobucket.com/albums/0903/Brian/Newpictures005.jpg)
Brian
Here is the spec
Stoke standard.
Corplugs new.
Cam profile.
Brian
Ben26
27-08-2015 08:56 PM
