Which Camshaft?
Tried cvh 34,35 and now on 36 and its the best by far try these www.racepowermotorsport.com it won't disappoint less lag and revs alot higher an allround excellent cam.
thanks guys,
I want to the kent site, and the specs of the "kent cvh 36" => BHP Gain = 0
Is this correct?
Because the "kent cvh 35" says => BHP gain = 26
Or shouldn't I listen to these specs?
Greetz
Is this correct?
Greetz
Originally Posted by pollocks
would cam choice also be affected by the turbo choice say would u have a diffrent cam for a t2 as aposed to a t3 ??
Where's Stu when you have a techy question
It's always a compromise.
If you go 1.6cvh low comp and 0.48 exhaust housing turbo then you want a low laggy cam like the CVH34.
If you go std 1.6cvh and 0.36 exhaust housing (like the std ERST T3) then you can go CVH35 and will not give you too much lag and middle and top-end power will be improved.
Dont forget to choose the right compressor Trim, IC, injectores, proper mapping, etc
I read a 285T2 VS CVH36 review. Can scan it so you guys could read it.
Originally Posted by Sean_RS
Originally Posted by Oranoco
I have heard that Piper's 285T2 is not at all well suited to the FRST
Ive got t3 with .48 rear housing, low compression and its far too laggy for my liking
hmm, before i go spending my hard ernt cash it would be good to see how this pans out.
im thinking of the cvh35 as i want low down and mid range power mainly, thats why im sticking with the T2 turbo, got all the other crap on to bring it to the P1 set up, beiges etc
It's not all about rr power figures mate
Would be nice if the cam lasts longer than a week aswel
I was running a 34 with my T2 and worked well then switch to T3 and went for a 35 and it was really poor, now changed to 36 and it pulls awesome and works really well less lag and smoother through the range with this setup and a stage 3 head etc etc.
ian howells oppinion on t2 cam-
"The 285T2 will never be right! Piper copied the CVH35 and altered the LCA by 8 degrees so not to be had under copyright laws - The ended up robbing all the energy that was available to spool up a turbo in the 3-4k region, but gained slightly on the top end HP.
Most people buy a T2 and think it's a fantastic cam because it's hardcore at the top end, but any CVH35 owner will know the diff immediately as the T2 feels gutless until it's seriously ragged. "
nuff said
Cams getting knackered in no time its because ppl dont lube them properly and dont even "run them in"!
I read an article 285T2 VS CVH36. I'll scan the article and post it here latter.
The results were something like this:
285T2 cam had more 2 or 3 bhp than the CVH36.
CVH36 cam had LOADS more torque from low rpm when 285T2 seems to be a NA engine at the same rpm.
The test was done without tuning the engine. Its a "straight out of the box" cam article.
Just by looking at the dyno graphs, can say that the CVH36 is way better on the road than the 285T2.
well im not in t3 league yet.. hybrid t2.
getting stu to set it up again on tue now new cams in, we'll see what it does at the rr.
Still not sure what to do with mine Power Engineering have recommended i go back to standard on mine by i just dont know
Think ill keep mine on a t2... i like the bottom en power, hopefully i get a nice read at the rr and ill be happy with the power and can just concentrate on the cosmetics.
I think it was just the major lag it has caused and said i would loose alot of that if i go back to a standard cam
Im the same i really enjoyed the bottom end power and really miss it even tho its great fun when the power kicks in
Yeah will be interested to see you car at the RR day
The standard cam is actually very good. I still have one in mine and made over 200bhp. A Kent CVH35 is on the cards as that's what I have in mine. Lou you are more than welcome to come out for a couple of laps at Bedford if you like to compare
T2 turbo and 34 cam
My setup is a pace double capacity intercooler, rebuild T2 turbo, rebuild enginge, 195 chip, -31 actuator and mongoose full exhaust line.
Would the cvh34 cam be the best in this case?
Or should I go for the cvh35 of 36 cam?
i think a 35 or 36 with your spec,im pretty sure you need to run at least 14psi with a cvh35 to get the best out of it,and you cant really run that sort of boost on a 165 chip. so 195 chip is better suited to a 35/36,165chip better to use a cvh34 i would have thought.
.48 exhaust housing lags more (up to 3800rpm on 1.6 cvh) than the .36 (up to 3000rpm on 1.6 cvh) but .48 since is less exhaust restritive it will give you more bhp at high rpm.
This is just a starting point from where to start looking. Lag also depends of the cam and chip (off shelf or live maped one).
foreigneRS
Technical essay Archives
20-07-2004 11:29 AM
foreigneRS
20-07-2004 11:06 AM
