PDA
View Full Version : Fiesta RS1800/RS Turbo
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14
  1. newbie help
  2. door cards
  3. Ashley Exhausts
  4. swap 1.6 to 1.8/2.0
  5. mk 1 fiesta wheel fitment?
  6. Ride Height And Wheels...
  7. rs1800
  8. more power
  9. T3 downpipe
  10. Fiesta MK3 Lights...
  11. RS Turbo owners, Fan Switch news!
  12. do i track my rst or make back to orginal form?
  13. fiesta mk5 2.0.
  14. Any body know this rs turbo?
  15. Convert my Fiesta Mk3...
  16. RS1800 Throttle bodied
  17. Longer gear ratio
  18. What gear box for 2.0 zetec conversion?
  19. 4 Pots from other Fords - Which will fit?
  20. Abs light on and speedo not working
  21. Has anyone put......
  22. lost all the water?
  23. Values
  24. housing 0.48 T3
  25. wheel spacing mk6 fiesta !!!
  26. cam for 350bhp+
  27. seatin upgrade for me mk2 xr2
  28. Mk1 brake upgrade - ideas???
  29. Fiesta RST idling problems
  30. EFI inlet
  31. Anybody got a ZS Anniversary edition?
  32. Fiesta Rs Turbo cams question...
  33. Fitting R1 Throttle Bodies on 1.8 16v Zetec
  34. rs chips
  35. Any ideas of what to do next ?
  36. Im looking at magnecor HT leads, but do i go for 8.. or 8.5mm?
  37. 4X4 conversion
  38. I need advise on an engine swap on my fiesta mk4
  39. Car disconnect yourself xr2i 1.8i Zetec
  40. fuel pump.
  41. Wheel spacers for mk3 fiesta
  42. Headlight protectors
  43. RS1800 Rear disc conversion
  44. ford fiesta mark4 1992 model
  45. High revs when changing up the gears
  46. RS Turbo Oil Choice
  47. My first classic ford! pics.
  48. MKII fiesta engine conversion question
  49. ib5 gear box
  50. Difference between mk4 and mk6 zetec engines
  51. gear linkages
  52. inlet manifold
  53. The past history my FRST
  54. rs1800 suspension problem
  55. drive shafts.
  56. beige injectors
  57. brake up grade
  58. picking this fiesta rs turbo up sat
  59. Fiesta MK3 rear wheelarch
  60. IAT help
  61. dazz1
  62. Tappet sequence & gap size ohv 1300cc 2000
  63. beige injectors? what are they worth?
  64. How to mount Focus 2.0 Zetec engine in mk4 fiesta?
  65. Fiesta rs turbo j610bwf (anyone know it)
  66. Tachometer in Fiesta Mk3 1.1 Carb.
  67. 1.25 full throttle problem
  68. Blue smoke on idle? Unused standard rs turbo
  69. red fiesta turbo what colour rear badge should it have please
  70. turbo should i do zvh or full zetec
  71. Help with Cosworth alloys
  72. zvh turbo build
  73. engine options for mk6?
  74. window regulator
  75. munster
  76. ZVH 1.8 to a 2.1
  77. fiesta rear braks
  78. efi frst probs
  79. Blacktop zetec into mk5 zetc s
  80. Fiesta XRV
  81. Ford Fiesta MK5 - What to upgrade!
  82. Zetec s engine
  83. Zetec-S clutch diameter?
  84. black top 2.0 into mk3.5 hcs fiesta
  85. Fiesta 1.25 zetec - first car
  86. rs block's
  87. Ofac Map sensor finis
  88. 145bh@'wheels xr2
  89. Radiator clearance for T3
  90. mk3 fiesta immobiliser
  91. t3 turbo convertion
  92. does the xr2i gearbox have longer gears then the rs turbo one?
  93. engine problem
  94. Help needed quick
  95. non starting help
  96. is the as a xr2i?
  97. fiesta rs turbo over heating
  98. Converting a mk2 fiesta front end to mk1 XR2?
  99. Ford Fiesta lowering Mods
  100. diesel exhaust back box
  101. speedo gear?
  102. rear disc conversion
  103. modifactions needed to transfer to cosworth managment
  104. cooling it down¬
  105. carb question
  106. carbon fibre centre console?
  107. fiest xr2i breaking full car
  108. Wanted urgent
  109. fiesta 1995 mk3.5 exhaust size?
  110. Rs/Xr2 fiest mk 3 body kit onto 5 door? calling experts
  111. New member & potential Fiesta owner
  112. FRST side skirts and arches
  113. help
  114. Fiesta RS 1800 Front Seats...
  115. Some pictures of my mk6.5 diesel
  116. fiesta rs turbo front bumper
  117. Rear Window Seals
  118. Engine trouble
  119. mk6 fiesta
  120. t2 turbo
  121. t3 conversion hose
  122. Non starting Fiesta Zetec S
  123. head gasket
  124. Group Buy - Quiafe Quick racks (Mk3)
  125. konis with spax springs good setup or bad???
  126. efi rs turbo beginner problems
  127. mk2 fiesta mod idea's but need help
  128. Which RST LSD for a Fiesta IB5 Box
  129. Mk3 fiesta with 1800/2000cc zetec queries
  130. Anyone bought the new fiesta ?
  131. Camshaft Selection
  132. Mk.3 Fiesta Power Steering
  133. Variable intermittant wipe conversion!
  134. Which Coilovers???
  135. Opinions please
  136. Rockers
  137. Rockers
  138. xr2i zetec to rs1800 spec
  139. endura DE fuel pump help
  140. Dodgy rumbling noise and vibrations on my mk 3 xr2i 1.8 16v
  141. t2 turbo oil return pipe
  142. XR2i 16v - misfire at 1-2k
  143. electric window problems
  144. do i have to torque my sump (cvh)
  145. carbon door panels???????
  146. hi
  147. forged pistons
  148. fuel leak on a fiesta 1.25
  149. Anyone Got Radtec Front Mount On their Fiesta?
  150. whats needed for 200bhp
  151. std spoiler or mondeo
  152. GRS alloy water swirl pot
  153. 1 ltr engine conversion
  154. chassis plate
  155. fuel pump
  156. leaking Fiesta RS1800
  157. from what car....
  158. antiroll bar
  159. will those fit a fiesta rs turbo?
  160. 3x TSW Imolas + 4 x Centres/Nuts
  161. Fiesta Zetec Probs
  162. frst gearbox
  163. should i flush.....
  164. mk6 fiesta engine conversion
  165. pls help fiesta rs turbo runnin probs
  166. Gearbox Help!!
  167. xrv help
  168. RS Turbo Power problem
  169. what else needs done?
  170. l.s.d.gearbox advice
  171. how can i tell.......
  172. 16" 7j et45, will these fit
  173. mk3 fiesta panels
  174. camber adjustable top mounts
  175. sills
  176. rs turbo boost
  177. xr2i 8v running issue
  178. Hi there
  179. My first car...
  180. turbo problem
  181. Running/Sparking Problems
  182. Where to get 058 injectors
  183. circulation fan problem
  184. best fiesta rs turbo
  185. TPS Sensor
  186. Fiesta RS turbo / xr2i fog light dimensions
  187. escort front mount on a fiesta???
  188. what power?
  189. rs mk1
  190. Wallet friendly Brake Upgrade
  191. what gasket
  192. suggested brake combo for my mk3 fiesta?
  193. will cossie 4 pots fit my mk3 fiesta ?
  194. super chip
  195. h504yma does anyone know or has owned this car ???
  196. will a erst block fit a frst
  197. some help please
  198. XR2 wont start
  199. difference between a mk3 and a mk3.5
  200. t3 conversion on a fiesta
  201. Intercooler & Rad setup
  202. Roof gutters
  203. what is he best engine swap for a mk3 fiesta?
  204. My RS1800i
  205. Swedish Fiesta XR2 -86
  206. heater resistor question
  207. Zetec Turbo Manifold Pics??
  208. iscv
  209. ET35 wheels on a mk6 Fiesta
  210. FRST hydraulic clutch / 6speed box
  211. were is this fiesta turbo
  212. cvh or zetec?
  213. zetec s powerflow backbox and collins superchip
  214. What Front Mount Requires No Cutting?
  215. Fiesta RS turbo with Hego?
  216. What breather with 2.1 full zetec??
  217. what bhp can i get from this????
  218. Mk 4 fiesta Si lurching problems
  219. OFAB / XR2i loom question
  220. gear box probs :@
  221. zetec wireing loom in a 1 ltr fiesta....
  222. map senser 3 bar
  223. fiesta turbo wheels
  224. Stage 2 Chip Fiesta RS Turbo Problems Help
  225. air temp
  226. MK3.5 interior question
  227. ABS
  228. Suspension suggestions
  229. This Forum
  230. fiesta turbo running issues
  231. Heat Wrapping Exhaust
  232. RS1800i colours
  233. mk2 fiesta suspension
  234. 130bhp cams
  235. fuel pressure
  236. No power below 4000rpm
  237. slow electric window
  238. rear axle for a 1.25 2001 zetec fiesta
  239. Zetec E/ CVH Engines
  240. Fiesta RS/XR2i history
  241. Fiesta 1.6 Zetec
  242. fiesta rs turbo cylinder head
  243. 130bhp zetec..??
  244. 17"s on a rst
  245. Induction Kit
  246. Anyone needing Fiesta rs turbo/XR2 spares in Aberdeen??
  247. Turbo conversion ?
  248. Help Oil Everywhere
  249. > Replacing Engine In 1990 Ford Fiesta, Having some problems
  250. Hello~
