some help please
Old Nov 16, 2008 | 08:16 PM
SCOTT81's Avatar
SCOTT81
Default some help please
my sisters FRST has started smoking badly on over run and iam putting it down to piston rings and maby needing rebore as i hav put new turbo and oil seals on and hav been offered good low mile s2 engine for it.............now what id like to know is can i use the s2 block bottom end and stick with the efi head?is it a straight swap bolt on job etc or are there differances with the block?any info would be greatly appreciated
cheers
scott
Old Nov 16, 2008 | 08:36 PM
KEVFRST's Avatar
KEVFRST
You will need to have a hole machined into the block for the cranshaft sensor. Everything else is the same I think. Do a compression test to check the condition of the bottom end before you spend your cash.
Old Nov 17, 2008 | 01:17 PM
SCOTT81's Avatar
SCOTT81
thanks mate
