Running/Sparking Problems
Old Dec 3, 2008 | 03:16 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Running/Sparking Problems
i have a 1.8 zetec with bike carbs that have been set up by bogg brothers
when i pull the leads for cylinders 1&2 nothing changes.
whin i pull the leads for 3&4 the engine stalls
there is a spark through 1&2 leads
3&4 plugs are jet black which is usually over fuelling but the carbs have just been set up, could it be anything else?
1&2 plugs are just grey.
the car barely accelerates so im guessing all 4 arnt running properly although theres a spark at every lead
any suggestions?
thanks
Old Dec 3, 2008 | 04:25 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Not a good set-up then?
Old Dec 3, 2008 | 04:40 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
well its more that 1&2 dont seem to be doing anything and the car takes 20 seconds to get to 60 its running that bad.
ive tried another coil but that didnt work
Old Dec 3, 2008 | 05:29 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Don't feel like going back to the people who apparently set it up?
Old Dec 3, 2008 | 08:54 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
well i was trying to sort the spark just incase its not their fault
but i might have to...
Old Dec 4, 2008 | 02:42 PM
danny_boy699's Avatar
danny_boy699
chatter 4 life
u sure it not the way it wire up mate, i know it was wired up bad, but probley been set up wrong
Old Dec 4, 2008 | 04:37 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
i was running injection when you saw it, its on bike carbs now using different management. it only has water temp, cps, coil pack, vacuum and rev counter
which im replacing, that might sort the spark on 1&2.
hopefully.
once i get a spark on 1&2 ill be straight back down to bogg brothers as 3&4 plugs are black...
cheers
Old Dec 4, 2008 | 04:59 PM
danny_boy699
chatter 4 life
you tryed new plugs mate
Old Dec 4, 2008 | 05:29 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
yeah there new plugs that are in now, well new since the set up a few weeks ago
all i can think is management...
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
