cvh or zetec?
cvh or zetec?
wats the easyest conversion for my hcs fiesta out of the cvh and zetec??
also is there any links to a conversion guide for any of these swaps??
thanx
thanx
YES I KNOW I CANT SPELL
a cvh is best as you can get them with a carb as for the zetec every one needs a wiring loom fitted and fuel pump ecu ect ect
depending on what cvh you use its a strate forward swap if you get the cvh out of thr fiesta turbo it will bolt strate up just rember to get the shafts breaks ect ect but that also needs a wiring in
if you get the cvh out of a fiesta mk2 xr2 or a carbed cvh of some sort you can use the fiesta turbo top mount and will bolt strate up
as for conversion guide a hanes manual has got very good instructiona in removing an engine
as for putting it back in just do the same in reverse
hope this helps
hope this helps
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
