PDA
View Full Version : Fiesta RS1800/RS Turbo
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. Fiesta Rs turbo gearbox
  2. Fiesta RS Diesel :D
  3. Guys do you know this car????
  4. my frst dn't know what to do next lol
  5. rs 1800 badge
  6. fiesta rs turbo spain!!!!
  7. Clutch pedal adjustment
  8. Help me value my RS turbo
  9. OFAB ECU dead need help!!!
  10. Chatter or bov?
  11. Fiesta RS Turbo (T2) Query
  12. Could this be synchros in gearbox....
  13. Turbo help
  14. 1.8 130ps feels flat
  15. any one know this car
  16. RS
  17. frst map sensor and edis module
  18. FRST hunting on idle
  19. What tyres on 16's?
  20. Standard Suspension
  21. RS1800 running ST170 6-speed
  22. wont boost like it did a month ago?????
  23. Turbo to radiator hose needed
  24. croydon fords
  25. lowered rs turbo fiesta
  26. act sensor
  27. rs turbo probs
  28. Fiesta Carbon Fibre
  29. whats everyone got against the rs1800?
  30. brake kit wanted
  31. what do you think of this?
  32. RS1800 dipped beam problems
  33. Fiesta rs1800 2.0l engine conversion.
  34. Threads asking for Car Stereo codes are not allowed.
  35. How much
  36. New to Fords
  37. driveshaft belt?wtf
  38. 165 chip, what do i need to change
  39. msd 225 chip question
  40. Mk3 Fiesta rear disc conversion (RS2000)
  41. driveshaft query
  42. mahle pistons
  43. please help rs turbo missfire and kangarooing !!SORTED!!
  44. fiesta rs 1800 electric windows probs
  45. Very quick question!
  46. Somthings not right!!!
  47. Compression Test Results?
  48. boost presure
  49. help with calipers brembo
  50. well all help wud be great on this t3 turbo kits
  51. injector help????
  52. Ofab Engine loom wiring HELP !!!
  53. Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hh help me lads
  54. well all
  55. what mods 4 240ish bhp?
  56. forge actuator
  57. ofac ofac difference?
  58. hello, ive just bought a frst.. 1800 zvh H875NVX and started work already..
  59. Fiesta Turbo Conversion Trouble !!!
  60. fiesta rs turbo bodywork
  61. RS1800 - running problems, help appreciated
  62. New to the Fords
  63. RS1800, anyone got one chipped/remapped?
  64. frst wont idle wen at running temp
  65. fiesta turbo ecu
  66. rs1800 won't idle! help apprieciated
  67. Fiesta rs turbo ecu anyone!
  68. rs1800 4-2-1 manifold more problems!
  69. Fitting 4-2-1 manifold RS1800 problems
  70. Where can i get Inner Sills for my RS1800
  71. Fiesta MK3.5 hub and CV problem...need help?
  72. Side skirt removal on rs1800
  73. h226 cdx
  74. How To Adjust Actuator? (Pre-load)
  75. fitting a new cambelt trouble.
  76. rs1800 injectors, need help!
  77. Engine cuts out when i turn the lights on!!!!! HELP!!
  78. RS1800 idle problem and flat spot, need help!
  79. Rewiring rev gauge??
  80. My 1985 Ford Escort GT Turbo...Looking For This Part
  81. my car wont boost past 0 psi????
  82. Carbon Bonnet vents
  83. OMP Roll Cage
  84. Which tyres to use on standard fiesta rs turbo alloys
  85. Fiesta t3 conversion help
  86. Wots the most psi a standard t2 actuator run..
  87. Fiesta rs turbo tuning help!!!
  88. Hi, and a few RS1800 Questions.. Sorry!
  89. EFI Vacuum pipes
  90. Adjustable rose jointed lower arms
  91. fiesta rs1800 low down tuning.
  92. anti roll bar issues
  93. Help needed t2/t25 gurus please
  94. FRST Parts (A Few Needed) also some advice.
  95. mk2 fiesta xr2 5speed: which driveshaft URGENT
  96. Fiesta Turbo Conversion
  97. In tank uprated fuel pump...
  98. water pump 1.2 zetec engine remove & Replace
  99. mk3 fez
  100. 1999 Fiesta 1.4 rear brake pipe
  101. Ford Fiesta Mk6 tail light upgrade
  102. 2007 3dr Fiesta Zetec Passenger Window Not Working
  103. MK2 Fiesta RARE part required - can you help?
  104. 1.25 Zetec power loss.
  105. fuel rail connector removal
  106. Drive belt routing
  107. RS1800 engine into a xr2i-loom help?
  108. mk3 fiesta sill plate
  109. Newbie with radio question
  110. Mk4 Fiesta cl help
  111. Fuel Surge / Starvation?
  112. frst
  113. max power 2.0 zetec bottom end ( turbo with decomp)
  114. RS1800 with mk5Rs2000 discs on rear
  115. frst engine loom needed quick
  116. fiesta rs turbo
  117. rs1800 misfiring. please help
  118. newbie needing help
  119. Is it simple to install a 1.6 zetec engine into a 1.1 fiesta lx?
  120. FRST Air leak testing
  121. Electric headlight adjustment problem
  122. My Fiesta RS1800
  123. RS 1800 engine issue.
  124. heater matrix by-pass
  125. Fiesta MK3.5 1.1 to 1.3 engine conversion, sounds silly but its the run about car
  126. ECU Pins 3, 23 & 24
  127. fiesta parts catalogue
  128. please help me lads!!!!!!!!!!!ahhhhhhhh......
  129. help me lads!!!!!!
  130. Fiesta boot won't open.
  131. Ford fiesta mk4 1.8 zetec
  132. Fiesta mk4 1.8 Zetec
  133. Which engine for frst restoration project?
  134. Fiesta MK7 Colours
  135. looking for info
  136. What intercooler? 2.1L ZT Mk5 fiesta conversion
  137. what you think of this rot then?? and mot man?
  138. OFAC - Amal Valve
  139. mk3 fiesta parts...
  140. FRST + L6 cossie ecu
  141. FREE Mk3 Fiesta wing mirror & indicators
  142. Did some work to the Fez today
  143. FordFiesta 1,1 i 1995 Cold start problem
  144. Some pics of the Fiesta
  145. RS1800 rear brake cylinder different to XR2i?
  146. escort gti wheels
  147. sun roof leaking, specific questions to answer please
  148. fiesta st seats
  149. Fiesta Mk6 clutch
  150. neeeeeeeed help
  151. 90 spec recaros into mk5 fiesta
  152. RS1800 running badly
  153. fiesta rst steering
  154. Where can i purchase charge carrier grommets
  155. HELP PLS Fiesta rs turbo brake load sensor valve
  156. John colley studios pf magazine feature pics :)
  157. Zetec s tdci
  158. cheap low boost zetec turbo?
  159. Fiesta brake problems
  160. Fiesta MK6 heater noise
  161. Fiesta Heater problem
  162. FRST Fuel Pump
  163. Will frst rear seats fit a mk2 xr2?
  164. tripods on fiestas? (posted first in tech forum...)
  165. Underbonnet padding
  166. fiesta st hunting help
  167. Fiesta RS Turbo Beige Injectors
  168. mk6 fiesta bad vibrations above 50mph
  169. heated front screen
  170. Grey trim pieces
  171. "Sloppy" gearbox - '98 1.3 Fiesta
  172. mk6 fiesta flame - which engine conversion?
  173. Mk3 Fiesta Rear quater glasses
  174. Handbrake adjustment problem
  175. in need of some help :-(
  176. Need a rs1800 under bonnet sticker!
  177. Boot Latch Panel
  178. H283 GTJ fiesta turbo
  179. need help fiesta rs 1800
  180. Engine loom
  181. fiesta pinking and smoking help
  182. fezzi mk2
  183. Retro fitting a Mk6 Fiesta trip computer
  184. 13x7 wheels: mk3 fiesta
  185. Rs turbo topmounts??
  186. MFI to EFI ?
  187. Proplem with rst mounts into mk1 fiesta
  188. Temperature gauge not working
  189. frst inlet air tem sensor req asap
  190. fiesta rs1800 steering wheel swap
  191. fiesta rs running lumpy ??? help needed please
  192. Help to a new member, "ford fiesta 2005 tdci"
  193. Zvh 1.8 conversion. What bits do I need?
  194. Mk2 Fiesta side exhaust !! is it legal ??
  195. rs1800 rebuild
  196. Rear Wheel Bearing
  197. which flywheel
  198. removing rear windows
  199. starter motor trouble
  200. HELP
  201. Other gearbox 1.8 xr2i
  202. fiesta 1996 speedo
  203. Fuel line ?
  204. Mk1 Fiesta rebuild (rs turbo engine)
  205. Ford Fiesta Mk3 XRV?
  206. Escort mk5 shocks to Fiesta mk3?
  207. frst oil breather vac pipe set up
  208. Favour please
  209. Anyone Turbo'd an XR2?
  210. ZVH in a Zetec S??
  211. Suitable car cover for outside?
  212. Can someone help with no oil pressure
  213. Ford accessory tinted rear lights
  214. Rear disk conversion, which hoses ???
  215. pic request - fiesta turbo oil breather system
  216. overheating problem
  217. ZVH Breather Return
  218. Fiesta MK7
  219. XR2i 8v EFI Gearbox???
  220. over heating problem
  221. temp question..
  222. SO i got my Fiesta RST yesterday at last! ONE QUESTION THO
  223. i only get stickys?
  224. Omex 600/Ofac wiring scematic
  225. Fiesta RS Turbo Project (need some help please)
  226. fiesta van 1.8d
  227. Fiesta 1.4 zetec
  228. IGN fuse keeps blowing on MkV (2004) Fiesta
  229. Wirring sound near aux drive belt on 04 zetec fiesta
  230. N/S rear 1/4 panel
  231. Frst backbox
  232. fiesta turbo ACT sensor
  233. does anyone re manufacture the FRST green side strips?
  234. New member
  235. mk4 fiesta, twitchy backend ??
  236. Fiesta courier derv running issues
  237. Broken tilt wires
  238. Fiesta/Focus ST170
  239. Air filter for a T3
  240. Max BHP and PSI
  241. Racetech gauges
  242. Fiesta RS1800
  243. Not a good day at the workshop!
  244. Losing water!!!
  245. mk3 fiesta doors HEP!!!!!
  246. gearbox differences
  247. mk4 lsd gearboxes
  248. RS1800 airbox
  249. ECU and Fuel Pump Problem...
  250. LSD gearbox on rs2000 block in my FRST
