Mk4 Fiesta cl help
Mk4 Fiesta cl help
Basically I have a 1.4 mk4 fiesta ghia, I have a key with locking buttons on but they don't work, do I have to install my own central locking or is it just broke? I am a complete newby to this else, Thanks.
Key only needs programming @ Ford for the PATS (immobiliser)
Remote fob can be learnt without Ford equipment.
Handy link :
http://www.lifestylefordparts.co.uk/article/show/17
Handy link :
You don't need the red key to learn the remote locking. You can learn the PATs with the red key and using key cycle sequence. If you've got more than one key make sure you learn both remotes at the same time, or the other one won't work.
If the remote key sequence doesn't work, try unplugging the central locking module that is next to the fusebox, plug it back in , then try the sequence again.
If the key fob is a 2 button (infra-red type) , it should have a sensor built into the interior light panel (like a shiny black lense)
Can't remember ever not being able to learn the remote on a Ford by using the key sequence method, the old Bosch immobiliser on mk1 Mondeo was a pain in the arse though
Steve Escos
01-10-2015 06:57 AM
