Fiesta rs turbo tuning help!!!
I've recently just purchased a fiesta rs turbo it's pretty much standard but I'm away to make it stage 1 with pace intercooler still on t2 turbo, I'm just wanting stage one as I'm away run it as a daily runner. Wots the most psi u can run on standard actuator on t2??
well in that case you will need to speak to who ever is supplying your stage 1 chip, I think MSD do a 165 chip so you would have to ask them what boost to set it at so it fuels correctly.
Hope this helps, might be work speaking to the following as well:
Sitech - 01796 481 495
Collins Performance - 01796 481 495
Oddkidd Creations - www.oddkiddcreations.co.uk
Norris Motorsport - 01773 836274
1 Post
stage 1 chip only removes (or sets a different level) of boost limit..
All depends on what ECU you're running
0FAB is running 8 PSI 0FAC is running just 7 or 7.5psi as the standard boost limit.
With a stage 1 (165) chip, the only thing done is to raise this boost limit to around 14 or 15 psi. and as the name states, you can reach around 165 BHP with it.
i have a 0FAC with 175 Ahmed Bayoo chip, doing a max of 15psi (before it cuts in) and does 198BHP (of course with some more adjustments like intercooler, cam, fuelpump, fuelpressure, T3)
paceo
03-02-2016 10:31 AM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
