Can someone help with no oil pressure
Hi lads, I've just put a engine into my frst, doesnt seem to hold oil pressure, oil light came on wen I started da car, it said it's about 11psi on da gauge at max and wen I rev it it goes up to 25psi maybe more and the oil light goes off, took the oil feed off the turbo and it just splutered out oil.. I've put a oil cooler kit on too and hav made sure to keep the air locks out.. Does anyone have any tips that will help me find out what the problem is, p.s. It seems to pump oil fine as checked it for that.. Thanks lads..
Engine Builder
mine too, on cold its about 70-80 psi and about 30-40 when warm...
things to check are oil pressure switch, like you say oil pump is fine
however, your oil cooler is moving oil further around before it gets back to the engine, its route is sump, into pump through cooler pipes, into cooler, back through pipes into oil filter then into the engine, its a long way for oil to flow, your pump may need upgrading to a higher flow rate to pump it round the cooler quicker
SMILER258
28-09-2015 09:04 AM
