Compression Test Results?
The cars been smoking quite abit and breathing heavy lately so first point of call was to clean the breathers, this made no differance. I also noticed a small mayo build up in the inside of the oil cap so I've done a compression test and this is what I found
Starting from cambelt side:
1 - 100psi
2 - 120psi
3 - 150psi
4 - 140psi
The car has a low comp bottom end with standard pistons and a cometic gasket, is it possible the gasket has failed? The car was rebuilt around 5k ago with a refeshed bottom end and new head etc so I'm abit confused as to how its failed so soon (if it has failed at all)
Any ideas chaps?
1 - 100psi
2 - 120psi
3 - 150psi
4 - 140psi
Any ideas chaps?
passionford pro
have you done a wet and dry test....ie spray wd40 down the plughole before the second test,helps diagnose if rings are worn.
also tell us how you carried out the test. cheers
I did the test dry with all plugs removed, throttle open and turned it over 5 maybe 6 times then took the reading. I'll go back to it tomorrow and try the wet testing method aswell!
07-10-2015 12:56 PM
