Rs turbo topmounts??
An eye for detail...
They're usualy fixed to the strut tower with bolts, and the strut is bolted solid to the centre section, the only movement you should get then is rotation with the wheel.
A normal/poly mount will still allow a little movement sideways and flexing, and more than likely in an up/down direction too, you might recognise this as banging when your wheel hops as you wheelspin.
This all depends on how strong the strut tower is though.
JK12
33
26-04-2021 12:09 PM
