fiesta pinking and smoking help
Old 11-09-2010 | 09:46 PM
jay simpson's Avatar
jay simpson
Default fiesta pinking and smoking help
hi all i have a problem with my fiesta 1.25 2001 freestyle
when i drive down a hill and leave the car run down in gear not pressing the throttle and come to a stop when i pull off i notice in my mirror a puff of smoke for a second or two then its gone dosent smoke any other times also i have noticed that its pinking alot when its warmed up to normal temp it has only done 79000 miles but dont know when it was last serviced anyone have any ideas for me or had this problem thanks......
Old 28-12-2010 | 08:14 PM
callumc222's Avatar
callumc222
Not 100% sure but pinking sounds like the timing...dont see how you could put the timing wrong on the zetecs though there simple as peas
Old 29-12-2010 | 01:22 PM
martysmartie's Avatar
martysmartie
That is likely to be valve stem seals as you are experiencing smoke on the over run which is a symptom.
Pinking as said is usually due to incorrect ignition timing.
Martin
sridgett
01-10-2015 07:30 PM
Steve Escos
01-10-2015 06:57 AM
DAZZER
30-09-2015 08:43 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: fiesta pinking and smoking help
