MK3 offset
29-12-2006, 05:52 PM
MK3 offset
is ET35 isnt it?
would an ET37 wheel still fit ok? or would i need spacers or anythin?
29-12-2006, 07:38 PM
The offset is et35. Can't comment on whether you'd need spacers tho I'm afraid
29-12-2006, 08:14 PM
what size wheel are you going for?
29-12-2006, 08:17 PM
15's, ive already got them, picked them up 2day...the ad said ford fittment but i forgot to check the offset like a fool
29-12-2006, 08:20 PM
should be fine most aftermarket 15's are et 40 and std ford are et35 so somewhere in between will be fine
29-12-2006, 08:21 PM
wicked, cheers mate
30-12-2006, 10:26 AM
Depends on the width, If there anything above 6.5 they may rub on the shocks. I had 6" et40 and they were fine.
30-12-2006, 07:31 PM
ET37 is usually ok, however its all down to width. You will probably need spacers of 3-5mm on the rear if you have drum set up with 7" wide as they will rub on the shocker.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Brickhouse
14
03-10-2015 07:28 PM
Steve Escos
01-10-2015 06:57 AM
liamT74
23-09-2015 10:24 PM
