efi head info needed
tomorrow im gunna be fitting a efi head to my zvh i need to know where the vacum hose on the bottom of the throttle body goes to and also where the 2 pipes in between injectors 1&2 and 3&4 go to aswell
nice one i thought it went to the FPR , the other 2 pipes come out the inlet manifold between injectors 1 and 2 and 3 and 4 , similar fitting to the vacum hose but a bit bigger and they join in with the inlet ports aswell
Im sure that's to the breather system number 3 on the pic there's 2 hose's that go into the 1 hose that then go into the 1-way valve then to the breather pot If that make sence
yup j that looks about right to me , cheers mate just one more question does the breather outlet on the right hand side of the rocker cover go direct to the breather at the back of the block ?
that pic looks like it was nicked from one of my old threads
yeah he's right, both vac out lets joint together via vac pipe which then goes up to a 1 way valve that connects to the small outlet on the breather pot
marky_g
15-08-2015 10:43 AM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
