What actuator?? T2 turbo
VERY HELPFUL! ^
Radders, just nipped on TT's website. have a butchers, should help!
http://www.turbotechnics.com/docs/co...t2actuator.htm
TURBO TECHNICS LIMITED
HIGH PERFORMANCE "T2" ACTUATORS
A brand new high performance actuator, designed to endure extreme high temperatures, is now available for the Garrett T2 range of turbochargers plus others.
High quality replacement actuators specifically designed to replace the standard T2 actuator on competition and high performance turbochargers. Specifications include, highest quality Nomex and flourosilicone diaphragm housed in a pressed steel yellow plated housing, with a wide range of springs rates, and a 50mm long, threaded wastegate rod.
Nomex and flourosilicone diaphragms for high temperature applications.
Full range of spring pressures available from stock.
2 x ¼ UNF mounting studs.
50mm long ¼ UNF threaded rod.
Single port hose connection.
Part Number
Pressure
@ lift
10364-01*
6.0 psi
0.41 bar
6.3 mm
10364-02*
7.5 psi
0.51 bar
6.3 mm
10364-03
10.7 psi
0.74 bar
6.3 mm
10364-04
12.3 psi
0.85 bar
6.3 mm
10364-05
13.5 psi
0.93 bar
7.4 mm
10364-06
18.0 psi
1.24 bar
9.4 mm
* Epichlorohydrin/ Dacron diaphragms
Prices
Retail price £49.95 each. Trade discount on bulk purchasing, contact Turbo Technics for details.Price exclude VAT and carriage.
Part Number
Pressure
@ lift
10364-01*
6.0 psi
0.41 bar
6.3 mm
10364-02*
7.5 psi
0.51 bar
6.3 mm
10364-03
10.7 psi
0.74 bar
6.3 mm
10364-04
12.3 psi
0.85 bar
6.3 mm
10364-05
13.5 psi
0.93 bar
7.4 mm
10364-06
18.0 psi
1.24 bar
9.4 mm
Prices
JK12
33
26-04-2021 12:09 PM
