- Grey injectors
- Sapphire abs fault finding
- front crossmember
- 3dr Cosworth Tcas.
- 3 dr standard wheels ,anyone fit spacers?
- Dark greens
- Whats the id and od of cossie fuel lines?
- Engine breather pipework
- 4x4 bonnet vent bolt thread size anyone?
- 3DR/RS500 Rear seats
- saff side skirt rivets
- Uprated gearbox mount on a saph
- DIFFS
- Water leaking from turbo?
- Could this be causing my plug fouling issue?
- big tooth kit mt75 2wd g box
- RS500/3DR Turbo Heat Sheild
- cosworth 4x4 wheel hubs
- TCA's are they all the same size?
- 3dr shocks, bilstiens or koni??
- Which tyre size for 16's on a Sapphire?
- Baffled Sump
- Thinking of selling the saph
- Anyone fitted a 4x4 pump and stat.....
- Fuel pump rewire
- Fecking rear brakes won't bleed!! help please
- standard camshaft id 2wd
- Carbon wrapped
- Companion cam for BD15+
- David Craig waterpump on 4wd Cosworth
- toad alarm help ahhhhh
- Saph cosworth rev counti size
- L8 ecu 4x4 cosworth
- Question about YB Pistons
- Amal valve
- cossie rods?
- Wastegate and turbo question
- BOB dipstick difference
- Vacuum hose size
- fuel pressure regulators
- Which wheels???
- 500 intercooler with or without dump valve?
- whats the value of old style cxn,s
- Urgent cossie help....
- alcon 6 paddle clutch. where from please?
- 3dr replica bbs wheels
- well thats the cosworth engine at the machine shop
- 4x4 cosworth help
- Pictures of standard sapp
- saph 4x4 Abs servo pipeing help?
- Any way of removing scratches from my glass
- Help Please
- ecu plug knock sensor lines?
- Help please strange noise under breaking
- plenum pipe fittings
- 17×7.5 Fronts/ 17×8.5 Rears 3 Door do they fit?
- I must have a guardian angel :-(
- Smoothing Sapphire Inner Wings
- Relay for cooling fans
- morette headlight cold air feed
- 2wd/4x4 Rear Beams are they the same?
- timing belt position
- broken exhaust valve
- 8J wheels on a saph
- yb timing belt bottom pulley
- Waterless Engine Coolant
- Rev counter
- Cosworth breather
- Checking my pistons for ware. Help please
- What cam to run cosworth yb with holset hx turbo gt3076
- wires for wiring loom?
- RS500 splitters for Sapphire fitment
- 300mm rear brakes, handbrake help
- Upgrade headlight bulbs for a 3dr
- 4x4 rear calipers on 2wd
- Changing throttle body
- People with hydraulic clutch conversions
- Has bling under the bonnet died?
- Brake master cyl
- Cosworth wont start
- What headlights are those
- Best way to remove drive shaft bolts
- 3dr heater same as sapph heater?
- Head bolts
- Mercury Grey Saff Cossies, How many made?
- 4x4 sapp passenger side top gear box bolt
- Which brake discs to use?
- mt75 4x4, what oil?
- Central day
- Bodykit,best stuff to stick arches with??
- Sierra 5.0 v8
- aeroquip
- 2WD Cosworth poor idle when cold
- Sierra heated seat wiring and switches
- When to change the oil on a YB?
- Final Drive in J reg sierra
- Been thinking of changing the colour of my hoses
- What brake pads to use????
- cossie ARP flywheel bolts, worth?
- loom earths@
- 2wd saph query
- 60mm lowered daliy drive
- Cos braided s/s brake hoses part kit
- cosworth 4x4 sump question
- which supra diff do i need to buy for conversion
- crankshaft bearing help
- Millers oils
- Alarm fault
- Advice for getting up oil pressure??
- 3dr front window glass?
- Rear axle camber shim pictures / measurements
- Headlights are crap at night
- Grey injectors
- Easiest way to remove alarm from a 4x4 Sapphire
- Change valvesprings..
- Bell housing bolts for T5
- 3dr glass h/lamp lenses...where from??
- Original side mouldings 3dr
- 2wd power steering racks
- WRC oil squirters with std pump
- Plug gap. Cosworth.
- Pipercross viper air filter ?
- Mot and headlights
- 2wd heatshield
- ABS Lights
- 2.0 dohc rear crank seal ?
- Running problems
- Juddering/Misfirey 2wd Saph
- PolyBushing a Sapphire Cosworth
- Custom bells for rotors...
- Sierra cossie 3dr & saph parts free
- Sierra mk1 bootlid info needed
- Saff Headlight protectors
- anti roll bar washer question
- saff cossie central locking motors
- Gaz coil covers for £549:99???
- SECS Monitor Settings
- rouse front splitter
- Avo 2wd coil overs
- wheel colour
- Mike Rainbird's Rear Shims
- Polished heat shield
- 4x4 cosworth
- Touring car style mirrors 3 door Cosworth
- 3dr throttle body, free to someone that needs it
- Engine lifting eyes
- Front hub flange swap?
- 3dr cosworth fuel pump relay wiring order
- Fuel tank paint or p/coat?
- Anyone replaced the rubber seals in the original 3dr/RS500 wheels?
- what mpg do you guys get ?
- Cosworth 4x4 rear calipers and carriers where from
- cosworth long studs
- My stereo is not working, help?
- few sierra issues c,l and heater
- 3dr front and rear windscreen seals still available ?
- wanted: pinto efi intake manifold
- power steering pipe
- Headlights
- Block Identification: RS500?
- Door mouldings
- Ecu and Loom fried
- Saph intercooler change
- Need help with block
- Close Ratio T5 Box Fitted
- Pretty things......
- Group A coil loom
- info on this ecu please
- Dodgy handling
- 2wd Saph owners...
- Elite IL300 in a 2WD Cosworth
- air injectors any good? worth the money ?
- Sapphire Cossie Indicators
- thermostat housing
- Counterweight hits the oil pump body
- strange brake pedal vibration
- Free xr4x4 shell
- 3 door centre cap locks
- billet fuel rails
- P8, WS and als
- 2wd sapphire bearing
- 205 block in 4x4
- spec-r cooler rad mounts
- Sapphire diff questions
- Colour code of red cos rocker cover
- chips
- will an exhaust of a 2wd saff cos fit a 4x4 cos
- Sapphire 5 year restoration , MOT day
- Power Steering pump Sapphire 4WD
- 4x4 sapphire ecu
- Relay Indentification 3 Door
- whats the best ? airbox or cone filter or cone filter in a box ?
- 4x4 cossie/2wd brake questions
- Piston Rings
- 3door project
- Roll cage in a saff
- petrol tank
- Zetec?
- what happened to the thread "Rare sapphire 4x4?"
- Saph 4x4 ecu issue
- Which tyres for my newly refurbed standard 3dr alloys??
- general buying advice
- T34 vs T35 (TB3403)
- Clutch peddle
- old school
- A pillar weatherstrips
- Need help with oil jet!!!
- Fitted my Cobra Imolas into the 3 Door
- saff cossie alternator
- Turbo kits for the 2.9 V6?
- Would anybody buy a cat c 4x4 sapph cosworth
- T3 & T35 turbo question
- Cosworth yb cylinder head.
- Sapphire cosworth
- 044 fuel pump
- Any pics of saphs with comp mo Flat 5's
- Cortina 1.6 to mk1 Sierra engine swap ? Advice
- 2nd gear input shaft cosworth
- sierra roll cage question
- Cossie Lhd throttle/clutch cables
- Info required on mountune mt21 &mt23 camshafts
- wireing woes of a 3 door
- VRT exhaust emissions
- Front brake uprades on a budget, whats available
- YBB powered Merkur
- Re build average prices?
- Uprated camshafts in 2wd cosworth
- 205 block fuel pump drive blank
- water pump help thanks
- Strut tops? Gaz Golds...
- Changing loom in 3 door
- 4wd std cams wanted
- HELP needed with cossie
- step 1 of 3dr project-making my shell rolling
- MOT
- Sapphire steering bush.
- 3 door and spec R strut brace
- Vibratechincs 2wd gearbox mount
- 3dr manifold?
- Diff Oil
- my sapphire in performance ford
- Running issues 4x4 sapphire
- Thread size for 2wd oil pressure switch?
- Sierra 2.0 Dohc Carb into a 1.8cvh idea's ?
- YB Piston ring question
- D623 SRB
- window switches
- Spec'ing up my 400bhp Cossie Lump. Have i missed anything?
- 2wd Saff owner new to PF
