strange brake pedal vibration
I'm getting a strange vibration when i gently press the brakes on my cossie.
It feel like the ABS working but when i press a bit harder it disappears. After driving for a wile it disappears...
What could it be? could it be that the brake lines were not bled properly?
Thanks
Thanks
I'd say warped disks too. I used to have this, if the disks aren't mentally twisted it disappears when you push the brake more, because the brake pads get a proper contact on the disk. But when gently pushing the warped disks kinda goes on and off from the pads and this creates the vibration.
Temperature changes can make the disks go from warped to straight so this could be why it disappears after a while. I also had this symptom. Also it changed with the weather too.
If the new disks get warped easily this could tell about worn bushes in the front suspension (or poor quality disks).
For some reason Sierra front end seems to be quite keen on ruining brake disks.
But this somehow just feels different... It looks like it's something with the pump or the abs sensors.
It's like it just pushes back when you touch it. If you keep the foot there it just goes away. Even when just barely touching it... It looks like it happens every time you touch it. Over time it completely disappears.
I'll try bleeding the brake oil first then changing disks.
