2wd/4x4 Rear Beams are they the same?
Im currently converting my 4x4 saph cosworth to rwd.Will i need to change the complete rear end i.e diff,shafts,arms,beam to 2wd items?or will 2wd diff and driveshafts fit in a 4x4 beam?
Thanks in advance for any advise.
Last Time, Get Off PF FFS
Apparently all u need to do is cut a bit somewhere of the top of the diff and it'll fit the 4x4 beam IIRC with the 2wd bits obviously lol.
Resident Wrestling Legend
the 4wd uses a 7 inch diff
the 2wd uses a 7.5 inch diff
the ratio's are not an issue is you are going from 4wd to rwd, the issue is that the 7.5 inch diff uses thicker shafts and 108mm output flanges , where as the 4wd one uses 100mm flanges and thinner shafts
also, 2wd cossie shafts are specific to the 2wd cossie, every other sierra/granada with rear discs, even the escos, uses the 100mm flanges and thinner shafts and are easily interchangeable with each other
there are 3 different shaft lengths on the narrow shafts, but only 2 on the 2wd shafts
the diff, even though it's bigger in the 7.5 inch variety, will still fit, the top slot where it all bolts in is just a hollow casting, so chopping this off to make it fit is not going to cause a problem as it will just make it 11.5 inches long rather than 12
that's the beam side of things taken care of, next you'll be needing to consider the arms, because the holes may be bigger on the 2wd ones to fit the thicker shafts through, although i'm not aware of anyone fitting the thicker shafts to different arms as the normal way to do this is buy a whole complete 2wd rear end
hope this helps
hope this helps
I always understood they were different and even with the 2WD, there are two different versions, something like Ford redesigned it by 5MM to change the geometry?
Dojj, out of interest how does cutting the top of the diff work, as the problem is the width?
Martin
Martin
the case of the diff has several holes with which ot mount the diff to the beam
they are all the same on the 7 and 7.5 diffs other than one at the very top, which is further out on the 7.5 diff
however, the bolt that goes through this runs from side to side so you simply chop a bit of the casing off to effectivly shorten the tube the bolt has to run through
also, the granada and sierra diffs are slightly different throughout the years as some granada diffs had 2 long bolts going through whereas the sierra had bolts that went into the diff and not through
this may explain things a bit better
see the smaller diff having a hollow section where you can see the bolt going through while the bigger one hasn't?
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
