- Please help - 1994 ford escort serpentine belt trouble
- escort Rs turbo cam rattle
- Focus rs/blacktop pulleys
- ford focus 53 plate
- Fuel system setup???
- Air purge solnoids xr3 130 ps zetec
- 2002 Focus LX 1.4 Running Rough
- vernier pulleys
- Fiesta st gearbox or helicoil?
- Management
- Focus RS mk1 boost problem
- Ford 711 1300 vs 681F 1600 engines
- Focus wont start
- O/D light flashing
- Escort RS Cosworth (over fueling)
- 2ltr DOHC bolt?
- T3 turbo screech
- Focus RS2 Problems overseas
- vacum feed on inlet with ITB
- rear diff mount question! cosworth
- Gti seats plugged in but not adjusting.
- ford jumbo transit 52 plate rear axle trouble
- Cosworth will not start!!
- will st170 setup go in mk6 escy?
- afr mixture
- Focus st170
- no pressure
- 2 wheel drive Saph how to set ignition timing??
- Mondeo TDCI cutting out when clutch engaged / also a intermittent p0191 code
- Zetec valve stem lenght.
- cosworth 2.9 bob v6 pistons
- low comp starting
- Crossflow fiesta head compatibility
- st170 help
- 1.8 Zetec very low on power
- Turbo dimensions
- St - 3 full leather recaro interior !
- Fuel Swirl Pot Setup Question
- focus 2006 what wheels
- Anyone no if escort s2 sunroof fits s1 mk3
- Air con leak
- rear hub nut
- Strange Noise from engine
- Mondeo Zetec 2.0 tdi computer problem
- Fiesta 2000
- Hydralic clutch
- Zetec RWD conversion
- cosworth plenum plumbing
- Tdci 1.8 turbo flutter from cold
- will i need to get cosworth set up after fitting new fuel pump
- Mapping omex 600
- Loom whores
- Clutch for Zetec Conv Help!!
- Granada 2.8i cutting out
- please help - 93 escort chomping through rear wheel bearings - advice needed!!!
- C max diesel running fault
- Buying Series 1 Need Help B23 GTY
- Focus 1.8 zetec revving problem
- Focus st Gauge problem
- car wont start at all
- heated seat wiring help
- Escort Cosworth Headlights
- grp A ignition loom
- T5 gearbox clutch arm plastic clips
- xr4i
- fiesta rs turbo throttle hesitation
- 4:27 diff
- First Cosworth.....
- Clutch slipping
- Mtx conversion info???
- escort van exhaust help please.
- 1.8 130 zetec engine helpppp
- fiesta mk6 tdci brake problem
- MOT failure help
- Help - fitting mk4 escort rear seats
- Focus 2007 1.8 tdci engine rattle
- PCS D200 dashlogger
- cosworth abs unit build
- Hydralic clutch set up
- cosworth tps
- Fiesta brake upgrade
- ford fiesta heater fan
- Cosworth running issues
- Mk4 fiesta conversion
- escort finesse electrical help
- YB Bottom end wear/rebuild - opinions
- Mondeo 2.5T acceleration issue
- Central locking not working since efi conversion
- Ford Focus ST170 cut out and now won't start P1233
- Spark Plug Gap Size of Mondeo 1.6
- focus st 2.5 hesitant under load and low boost pressure
- Mondeo loom - adding coil pack plug for 2l zetec
- Anyone seen this before on a fezz
- Focus bonnet catch nightmare
- Ford Focus MK1 (phase 2) indicator problems.
- Petrol Gauge Issues
- Cosworth engine loom
- Steering Fluid Not Going Through the System
- Escort T25 connctor
- Help needed with ABS piping
- HELP!!!! RST S2 Radio Wiring Problem
- 92 sierra dohc paint code? where is it
- RADIO/CD
- Mondeo Steering Pump Problems?
- transit 2008 2.4 tdci misfire plus fuelling issue!
- Removing cossie rear arm bushes
- 803 injectors when to fit
- S2 starting and idling problems
- Mondeo 2.0 tdci 2002 clutch for single fywheel?
- ford special tool 303-507
- Wheel Studs and Gearbox???
- ST170 juddering when accelerating, Ideas?
- rs1800 inlet - what goes where?
- 2.8 help
- no fuel or spark
- Nav/reverse camera issues
- Wiring diagrams help
- key fob
- escort gti turbo boost problems
- Timing problem with Focus 1.6 Zetec
- 205 cosworth 4x4
- camshaft bearings issue
- Turbo Blue Smoke
- L8 upgrade
- Frost warning sensor Ford Kuga
- dellorto 48 set up
- mondeo mk3 53 plate misfire
- Where can i get IMRC arm/rod retaining bush
- re imobiliser
- escort mk4 inner cv joint help!
- Mondeo Rocker Cover Cracked
- MK3 Fezz Turbs lower arms
- Mk4 escort van indicators!! Help!!
- Designing an inlet manifold for YB
- Car wont start after new clutch and flywheel!
- Info and help needed on zetec conversion wiring and inlet!
- Mondeo mk3 bad brakes
- Headlight improvement
- Mk6 escort steering lock keeps blowing fuse?!
- Painting Wheels
- my transit 2litre td keeps kangarooing
- Removing parcel shelf supports from Mk4 Escort.
- Granada mk2 cosworth swop???
- Portsmouth Area Forum Users??..
- focus st170 bleeding rear brakes
- rover turbo inlet questions
- ford ka 2004 overheating
- Advice needed please.
- Does My Focus Have a PCV ? Mk1 1.6 Petrol
- Sump gasket leaking after replacement!
- focus st3 spare wheel
- Hard vs. Braided brake lines
- DCNF's on XR2i
- MK1 Focus - Clutch Master Cylinder O-Ring
- 2.5 Duratec O2/lambda sensors question.
- Focus ZETEC SE issues :(
- Door Central Locking wires focus.
- cozzy loom earth
- my new porsche brembo rear brake upgrade, pics added
- Focus Electrical Problem
- none running focus
- Door Actuator remote central locking kit
- Wasted spark loom
- cosworth crankshaft regrounding
- Air in fuel system? Cosworth
- Sierra 4x4 dying on take off
- making new loom for my zturbo xr2i help needed with wiring locations!
- Help with wiring on zetec conversion
- 3dr misfire
- More 3dr wiring problems!
- VW Touran brake options
- This is a very interesting one
- Locking Nut
- HELP Sierra cutting out
- Autospecialist manifold
- Fiesta Seats
- Focus 2ltr forged pistons/rods
- Fiesta 2004 Drivers door lock.
- Ford 1.8 Diesel Fuel Pump
- What oil?
- Mite sell my s1 how do I advertise it
- Will turning the fuel pump up affect MPG
- V6 Cougar erratic fuel gauge needle!
- HELP Cosworth Auto Electrician Required Urgently.
- turbo id
- Will this gearbox go in my van
- flywheel bolts
- Escort RS S2 set up question please read
- Roughly 30 miles to £10 of fuel, sound right in a V6??
- Lamda Sensor
- 99 Focus 1.8 zetec Power Steering Leak & and starting problems.
- 15" wheels and ST170 brakes
- What size thread
- Small turbo escort cosworth management
- Facelift Fiesta St dash in pre-facelift van
- Wiring diagram
- how to bleed rad????
- what to use to bond 3dr kit on
- Ford Focus 1.6 TDCI Oil leak
- Gear change issues
- ford fiesta si 16v althernator bracket
- 3dr cosworth fuel pump relay wiring order
- how easy to change a door?
- what mark is my fiesta? 5 or 6
- St170 interior into zetec mk1
- St170 throttle body on a 1.8 zetec??
- RECARO badges
- 3dr cosworth more problems!
- re wiring cosworth fuel pump
- Filling gearbox T5
- relay relay
- Fiesta kit fixing
- Ecsort van 2002 Haynes Manual do they exist?
- Escort van 02 plate heater matrix can it be changed without removing the dash?
- Duratec 1.8 camshaft
- als
- Fitting a fuel pump
- 3 dr cosworth speedo bouncing!!
- 2002 Escort Van heater only blowing cold air
- cosworth oil ball bearing bung
- Mk4 escort van fuse box!
- Advice needed.. 1.8 TDCi, suspected injector problem, common fault?
- How easy is it to install anti-lag to my RS Cosworth?
- anyone know anout orion mk1 interior light loom/relay
- fiesta heater switch problems
- Electric Window must be possessed!
- rs 7 spokes on a 3 door.
- Weber carbs bogging
- Having fuel trouble
- ford mondeo 2001 estate clutch no response ?
- Main beam new loom fitted
- Grey Injectors
- Mk3 mondeo 2.5 v6 inlet manifold/water problem
- Would 8x17 et33 alloys fit escort rs turbo
- focus heater reisistor wiring question
- Getting a mk1 1.8 petrol focus remapped?
- sierra rs rear trailing arm abs clips
- Bulbs
- cosworth dignostic plug
- mk 4 starting issue
- brake master cylinder mk2 escort
- jerking Zetec turbo @ 2500 rpm
- Transit 2.0 tdci Glow Plug Light Flashing loss of power.
- fuel gauge
- Correct jets for a 1600 crossflow
- HELP ME PLEASE!!! Cosworth oil/water mixing
- Setting up pedal box
- Ford fiesta 1.3 2002 finesse: cannot disable alarm
- fiesta st EAC failure. URGENT HELP PLEASE!!
- Any peugeot techs in ???
