Designing an inlet manifold for YB
Old Apr 16, 2013 | 10:02 PM
nixon_2wd's Avatar
nixon_2wd
Default Designing an inlet manifold for YB
Hello! I am currently trying to model up an inlet manifold for my cossie. Could someone help me out with some measurements? Will need the spacing and orientation of the bolt flange on the cylinder head aswell as the spacing between the inlet ports! (center to center!)
A measurement of the cylinder head inlet port would also help!
Thanks!
Old Apr 25, 2013 | 05:06 PM
nixon_2wd's Avatar
nixon_2wd
anyone?
Old Apr 25, 2013 | 10:42 PM
black_jack's Avatar
black_jack
Black Jack
There are things you could do - like get a stock gasket and work from that, alternatively, make a template from the head bolt flange or original inlet manifold, or use a stock inlet manifold as a pattern, its not a simple shape and you would need accurate technical drawings of the bolt flange and the correct size and shape of the inlet ports
Old Apr 27, 2013 | 06:41 PM
nixon_2wd's Avatar
nixon_2wd
Yes, that is why I am asking for accurate measurements Just thought to check if someone had them, as I do not have an inlet manifold to copy myself
Old Apr 27, 2013 | 07:48 PM
dissmalrs's Avatar
dissmalrs
i might have a spear inlet laying around can use if u like
Old Apr 28, 2013 | 08:36 AM
nixon_2wd's Avatar
nixon_2wd
This is what I have so far, I was hoping someone could verify the measurements for me? All in mm.
Old Apr 28, 2013 | 02:55 PM
nixon_2wd's Avatar
nixon_2wd
spacing between cylinders is 102mm, just found out. no need for this thread
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
caprixpack
Sep 25, 2015 07:53 PM
