2 wheel drive Saph how to set ignition timing??
As above title really have had engine rebuilt so dizzy has been removed and put back in, I had the car running a few weeks ago and all was fine stupidly I moved dizzy as I thought timing was not quite right now I am going round in circles and the car won't run at all!
I had left it alone as have been building up the rest of the car but tried to set it up tonight with no success!
I timed up pulleys so was at tdc lined the dizzy up with the cut out in line with rotor arm but still no good don't know if it is because dizzy has been out!
Is there a way to start again from scratch any suggestions welcome cheers Ben
afaik your ECU will sort the timing and you really don't need to 'set' the distributor as such. Lining the rotor arm with the mark on the distributor should be sufficient. I normally set the aux pulley mark too when timing and ensure distributor connector is fairly close to the cam pulley cover. My guess is you have another issue somewhere
Timing marks on cam shafts point at each other.
At TDC you should have a lug on the bottom pulley directly on the CPS with correct air gap.
Dizzy rotor arm should point to the line on the edge of the dizzy.
done.
done.
Just to add.. Next time leave it to someone with experience or you could do more damage than you expect. Messing with timing without correct tools and know how can only really end up with one end result. Either not working or worse..
JoeyBoyden
Jan 4, 2024 02:36 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
