- Power fold mirrors
- Cheapest way to get MORE power and LOWER consumption?
- tddi
- rs focus man in trouble!!!
- Focus RS tinted headlight pics plz
- Focus Engine Conversion. What's best???
- Interior Trim
- blanking the egr on focus 1.6 se
- focus 1.6se 2001
- Fit Centre Armrest
- ST170 Calipers - what are the casting numbers?
- ST170 emissions MOT fail
- what do u think (wheels)
- Idle problem
- Shawspeed 170bhp kit
- Difference between 1.8 and 2.0 blacktop cams
- FRS throttle body on 2.0 130KM
- pics of focus RS's with mudfaps & info
- Help pls need a focus rs drivers wing
- focus rs grill help!!!
- ST170 - Mintex Pads don't fit?
- what turbo's will fit
- RS mk1 suspension knock
- suspension
- Knocking when turning left at low speed?
- Focus RS 2009 workshop manual
- Can you help
- Speedo/Clocks Problem
- i have both
- Focus RS - Swirl Pot?
- whos white frs is this?
- HID light convesion
- are rs doors the same as std focus doors?
- Wheel fitment
- Knock sensor
- zetec turbo agian!!
- Reverse light help..
- dual mass to solid on st170
- Throttle Bodies
- Exhausts!!?
- Smoked rears
- Need a focus rs turbo
- Ford Focus Zetec 2001 X Reg Broken Cigarette Lighter Problem Help Please
- How to get wires from the engine compartment to the inside of the car on a Ford Focus
- cylinder head help
- HELP.
- focus seats
- focus lx cutting out
- Turbo-timer
- Focus rs mk1 ppl alarm fob
- rocker cover oil leak and ford dealer
- Main Beam ?
- Focus rs splitter on ebay
- Turn Auto lock off
- focus 2.0lt estate
- st170 brake disc change
- ST170 Power Steering Pump.....
- Focus rs mk1 talk to me
- 0-60 times and in gear acceleration
- any focus rs spares forsale or breaking pls?
- Focus RS bumper fitting
- First time tuner
- Headlight Help??
- ST170 instrument cluster
- Ignition system wiring
- Primary Designs exhaust
- ST 170 - Global windows close/open and auto lock
- Black-top Clutch question.....
- st170 cambelt
- 2.0 tdci focus tuning
- Engine Problems
- hi
- cvh rs turbo in focus
- st170 focus rs flywheel ??
- ST170 dash and ECU pin functions
- What is this for please?
- My mk1 focus rs (hi res photos)
- Changing my gear knob
- Mk2 1.6(100) mods
- focus st and rs rear brakes advice
- focus adjustable bottom arms
- Focus TDCI 2.0 130BHP vs Mondeo 130BHP?
- New Discs and pads for Focus RS Mk1!!!
- ST170 ABS
- rwd Focus conversion kit
- ST170 Gearbox problem/issue
- Mk1 focus rs ( pics lots of pics..! )
- focus st 170 cambelt
- Exhausts
- need a bit of info please fitting a st170 box onto a 2.0 zetec
- New RS Focus Any available?
- Need a setup!
- 02 focus zetec 1.6 oil change
- st170 engine gearbox in mk2 focus?
- wheel bearing
- Which 17s fit an RS...
- focus 55reg belt change.
- Door lock bolt size ?
- Anyone know standard RS engine specs???
- show us our 5dr focus
- 2003 Focus RS
- Focus RS 2009 work shop manual
- Any ideas
- Help?
- workshop/repair manual
- looking into buying focus, FAQ please
- ST170 Gearbox Linkage Rattle
- door card inserts
- difference between focus rs mk1 and mk2
- Just a quicky ?
- my mids and tweeters fitted
- mk1 Focus RS info required please
- New Ford Focus RS
- 2003 focus front subframe
- MK1 Focus RS Work Shop Manual
- my new round thingy :)
- Custom remap and Cam options for ST170?
- ST170 opinions...
- silver/grey mk2 rear bumper
- chrome styling
- Focus RS Mk1 1 Tuning Advice
- help, looking at a focus RS
- Focus RS 2 wheel 19x8,5
- 04 st170
- Dtc p1518...again!
- best remap for focus rs?
- Focus ST170/RS
- Ford Focus 1.8 zetec petrol
- Valve springs?
- st170 interior
- new ST170 owner
- Focus RS Headlights in to a MK1
- Re-Bore in the derbyshire area
- Focus St170 Heater controls
- Ford Focus Losing Power
- Anyone run the Pro-Alloy intercooler on a non-RS Focus?
- n e 1 had n e major probs with the rs focus
- standerd ford rims
- Front Splitter
- focus wrc spoiler and frt bumper
- Focus sport
- focus 60 pin ecu. pin 52? And what the hell is a cannister purge valve??!
- quick
- RS Focus misfire
- focus rs cutting out when revs drop
- RS Headlight looms
- Smokey engine (First post)
- ST170 Rims
- what oil(1.6)
- help needed
- re-maping a re-mapped FRS
- Sherborne castle
- ARB'S
- US Tail Lights
- SPOTTED: New Focus RS In White (M62 Huddersfield)
- Mates Focus ST problem...
- advice on looking for a rs focus
- rear end knocking
- how low on a ford focus
- New to ST170
- post your focus
- st170 oil TEMP & PRESSURE GAUGE
- Ipod with std Headunit
- Not sure just yet ! But need some advice
- Focus 1.6 engine swap
- Genuine Ford Focus RS Front Bumper
- HELP need info on Cosworth WRC Zetec piston YC1330
- Tax???
- hiya guys and girls
- Focus advice needed
- Advice when looking at Focus RS
- Anyone know anything about this focus - Reg '27HRH'
- ford focus collection kit
- Focus brake lights/front lights
- uprated diff
- fuel and temp guages
- Ford Focus Air Con
- got a problem
- st170 moding
- 2.0l focus to st170 ?
- Replacing ST170 Alternator
- Focus 1.6 Tuning Modification. Zetec SE
- Poly Bush Anti Roll Bar
- Focus to Focus RS conversion
- strange noise, hissing
- Ford Focus 1.8 TDCi?
- 57 plate focus estate roof rails
- My Ford Focus 1.4 16V Zetec SE
- Zetec Turbo Gearbox Options
- ST170 Alloys
- Want advice to turbo a focus st170
- Focus Rally Gearbox Help
- question to focus rs owners
- Focus rs emission proplems!!!
- ford focus se engine
- Suspension
- focus st170 goodies
- Other than Eibach?
- tow bar for a 3dr focus 2003 wtd
- Laguna Splitter on ST170
- Updated with new post 14/5: ST170 with Fault Codes P1518 & P1519
- Calipers setup ?
- Any modified mk1 Focus Estates on here?
- pullin away sounds like a deisal?!!?!
- st 170 juddering when driving
- Speedo clocks not working Help!!!
- bit of help needed
- timing marks on ford focus 1.6
- Kent Cams 2nd hand prices
- Focus 03/04 TDCi sport
- Focus 1.8 engine shaking HELP!
- Chatter
- Focus RS
- brembo caliper thread size help
- ST170 Spacers..
- 1 or 2
- RS focus gearbox to Zetec engine !
- Desperately need st170 wiring diagram
- ANTI LAG
- anti lag
- Focus rs cat backs
- Getrag torsen shims
- help identify this type of focus
- Focus 1.6 Ztec SE Crank Pulley Totque Setting
- focus rads???
- Mk3 fiesta with 1800/2000cc zetec queries
- Asbo rs focus revival begins 16/04/09 watch this space
- Focus RS Stage 1
- Step by step guide to fitting hids on a focus
- ST170 front bumper lower trim
- st170 discs and pads upgrade advice???
- 225/35/18 on a focus?
- Guide on fitting HIDs?
- What oil type and any tips on oil change?
- moondust Focus mk1's on 17's - Show me yours?
- Focus 1.6 se engine????
- focus cruise control
- bollocks selonoid replaced but rear door still wont open....
- Central Locking not working
- 16's on an ST170?
- Focus 1.6 brake upgrade, help please...
- wot to look for
- focus estate tdci lowering springs
- Collection front bumper and SEAT LEON SPLITTER,
- 07 and facelift panels?
- how to remove the inside door panel of the focus
- mk1 focus 1.6 remap
- First 09 Focus RS on the road
- Mk1 99 focus niggle through the steering.
