- help with new seats
- throttle body
- Please Help! - Air filter change Focus RS mk1
- Replacement front wing for mk1 frs
- **WANTED-Black FRS MK1 Lights Front&Rear**
- will this fit the rs? will it look shit?
- Need frs mk1 body parts please!!
- Mk1 frs central locking
- New mk2 rs steering rack?
- New Guy
- mk 1 frs - talk to me
- focus airtec radiator?
- Mk2 focus rs miltec exhaust keeps coming loose at turbo
- overboost problem
- what afr should i run?
- a few problems!!!
- Mk1 FRs box and atb
- Focus RS mk1 boost gauge firttment
- best deal on clutch rs focus
- Focus RS cold start problem
- trouble with my dreamscience
- swapping ecu's
- hi all looking for some help please
- Mk1 frs stuttering under full boost
- new member
- Focus RS Direct...
- Focus RS Rail differences?
- Mk1 FRS clutch
- New to Passion ford
- RS02 BOO mk1 focus rs - anybody know it?
- Help engine problems rs
- Mk1 heater gauge holder
- fccus mk1 engine
- Focus RS MK1 intercooler kit where from ???
- Focus rs mk2 best place to buy parts
- Focus rs mk1 gtx3071r
- Focus rs mk1 tubular manifold Info/help
- Looking at purchasing a MK1 FRS
- focus 2.0l zetec car - Full RS conversion
- What size V-band clamp
- Newbie
- Standard throttle body
- brembo caliper torque setting?
- clutch
- what gearbox oil for focus rs
- inlet manifold
- mk1 focus rs rear wheel bearing
- FRS no's 0002 and 0004?
- Best cheapest place to buy a new clutch plate
- any1 on here own my old mk1 rs focus reg was P77FRS
- Mk2 focus rs running problem
- Fitted car cover focus rs mk2
- Focus rs / st miltec can you use a st one on rs mk2 ?
- Mk1 focus rs power steering problem
- My new mk1 Focus RS.
- Focus Zetec World record
- Speedo not reading correctly
- Focus drivers side mirror
- Hub spacers or axle?
- idle problem
- Mk1 RS newbie
- focus rs mk1 intercooler
- Focus RS Front bumper mk1
- Focus RS Misfiring at 4000rpm
- GAZ GHA Coil Overs
- RS plates
- Focus RS MIL Eliminator Light Fix
- RS Focus exhausts...
- Bailey Motorsport DV30 Re-circulating Dump Valve any good?
- mk1 FRS dump valve
- 2 x Sparco 3 point black harnesses
- Focus RS Airtec Front Mount Intercooler
- Focus RS 350bhp K&N Induction System
- Focus RS Mk1 Standard Chargecooler Refitting Help!
- ipod connection
- KW or standard for road use? (mk1)
- greece focus rs
- Focus RS MK1 Carbon Fibre Splitter
- Purchased #0005
- steering pump problems???
- Difference between the Focus Mk2 RS and the ST 2.5 engine
- Mk1 frs map sensor?
- flywheel dimensions?
- Ford Focus RS Front Suspension Arms / Wobble Problem
- Anyone know LM52 FDX Focus RS
- Mk2 focus rs MP350 INLET MANIFOLD ??
- Dump valve / resonator box
- Mk1 Focus rs component question?
- Cambelt change frs
- Focus rs engine build
- frs mk1 brake choice
- Mk1 Focus rs ecu pinout??
- RS loom question
- Mk1 rs carbon parts
- Collins Performance maps mk2 FRS
- MK1 focus rs owners..................
- Focus struts, springs and top mounts on a transit connect
- FRS Speedo not working
- Any ideas (my focus)
- RS MkII bluefin
- Whos had a mk1 frs and a mk2 frs?
- Diffrence between Ford Focus RS Stage 1 - Stage 2
- Max power of standard frs engine
- flo -flex complete rear kit
- Rs Transplant
- mk1 focus rs clutch pedal spring
- Brake testing
- Scangauge
- Focus Rs build number
- 2010 ford focus rs leak
- Hybrid turbo advice
- Swirl Pot Setup on FRS
- Running Direct
- mk1 focus rs parts
- Buying frs mk1
- New Member RSRick3290
- which high powered zetec turbo clutch?
- Mk1 Focus RS carbon
- Help!!! mk1 focus rs using oil!!!
- Mk1 rs re-circ valve
- Focus RS mk2 400+ upgrade, and why you should not use the standard inlet
- bit of help needed
- Oil Temperature Gauge Sensor
- Anybody do me ae map nort east?
- Where Can I Buy???
- Focus rs remote fob inop
- my rs is pissing me off in the mornings when cold
- how many rs mk1 was made
- mk1 focus rs rear trailing arm bushes
- Does this car have Lux Pack 1?
- eBay manifold
- white alloys or not!!!!
- focus rs jumping out of 1st gear at traffic lights etc
- Focus Rs Inlet Manifold fotting onto a 2.1 zetec
- How High Do You Ride?
- focus rs, 70mm chargecooler or front mount intercooler? also which radiator
- mk1 rs cutting out!!!
- picked my focus rs up yesterday and love it, ex vauxhall owner lol
- mk1 FRS splitter
- rs focus been sat a year on drive
- Bells/rotors
- Ford focus rs mk2 navi system Blaupunkt SOS BIG PROBLEM
- MK1 RS Seats
- Gate pressure for mk1
- engine rebuild help
- Oil/water lines for GT2560
- Anembo billet plenum
- best lowering springs for focus Rs
- 4x4 transverse gearbox to fit focus rs
- Fitting 007DV to focus RS
- jamsport
- focus rs misfire
- Cam Specs
- Which dv for focus rs
- Newbie question
- mk1 focus RS
- BCS exhaust mk1
- focus rs coilover knocks help??
- focus rs track width
- Kiwi obd and iPhone app
- Focus RS Mk1 Alternator Belt
- help!
- Focus mk1 rs mats
- Door Ajar Light
- Want an rs mk1 I think
- Map Sensor Vacuum Hose
- MK1 RS Brake light?!?!?!
- Mk1 focus rs valves problem. HELP!
- focus rs conrods?
- Focus RS2 AP brakes
- Mk1 power figures
- lightened flywheel
- Brembo dust seal fitting
- Headlight Bulbs
- Does anyone know where to get these hood vents?
- FRS Tuning & Bluefin/Dreamscience Discuss
- Few picks of mine RS.
- door mirrors
- tumbleweeds
- WN53YHU
- Mk1 FRS Injector Flow Rate?
- Focus RS Chassis number
- Threads asking for Car Stereo codes are not allowed.
- Wheel Centre Cap Dimensions
- Focus RS Mk2 tyres
- Carbon front panel trim
- Focus RS Brembo's
- unlocking the digital dash to display tempratur
- RS MK1 Steering shaft
- Best Dump Valve For FRS
- RS Replica Build - Xenon Headlight Help Please
- Comp Test on FRS
- usb stick
- mk1 frs - uprated fuel pump?
- Your running costs...mk1
- clunking when being pout in to gear
- focus rs parts
- MK1 FRS phase 1 and 2
- Needed- Part number for Turbo-cat clamp
- Pic Request: Std DV set on FRS
- Some help/understanding regarding Chargecooler / FMIC
- MK1 RS Gearbox/Clutch ??? Weird Problems
- zsw zs1 wheels, do they fit????
- Rough list of parts needed for 4wd cosworth conversion ??
- Oil Slick!!
- new forge dump valve
- Wing mirror dilema
- Looking for spoiler mk1 focus
- Focus RS Mk1 buying advice
- clutch kits and lightened and balanced flywheels for mk1 focus rs
- Headlight/HID fitting questions
- car throwing up this code
- RS mk1 decat
- focus rs ecu's and mapping
- Revo Knuckle on a Mk1 Focus
- Frs mk2 itg or mountune airbox?Spec r or airtec cooler?
- Blu fin question
- MK1 FRS induction hose for turbo?
- mk1 focus rs= are both fans supposed to come on?
- mk1 focus RS production question
- mk 1 Focus rs engine bay
- mk 1 Focus Rs YC03 YNY
- mk1 frs on pectel t2
- jamsport mk2 focus rs 400hp kit are they any good
- MK2 FRS air boxe/filter change
- mk2 FRS dump valves
- roose hoses where they go
- mk1 rs front bumper width
- Oil feed restrictor
- frs wing mirrors
- mk2 rs clutch issue whilst driving hard
- 3rd rear seat install in rs mk2
- How much boost are you guys running on your standard frs engine+turbo?
- Focus RS 1827
- ecu diffrence's ?
- transit connect rs HELP!!!
- anyone know where i can get........
- mk2 forcus rs are they worth it
- Big Brakes Upgrade Help
- vacuum lines focus rs mk1
- st170 big brake conversion?
- Headlamp Washer Covers
- R5 RST - St Helens
- Are all focus MK1 wish bones the same through the model range.
- Focus RS mk1 cutting out now and then. Any ideas?
- Sorted the aircon today.
- mk1 RS rear discs
- Changing the Thermostat and Thermostat housing frs mk1
- #1479
