View Full Version : Ford Focus RS
Pages :
4]
12
13
14
15
- Thermo housing leaking
- Focus rs mk1 internals and head .
- code reader
- My cheapo brake kit....
- thoughts on de-wipering rear
- Newbie here :)
- which tyres
- code reader
- ford focus mk1
- focus tdci sport imperial blue anyone?
- funny creaking noise
- squeaking noise and gearbox help
- Superchips Bluefin for 1.6 Zetec SE
- pain in the ass 16 mk1 focus
- Knocking noise from rear
- tivct 1.6 noise
- 2003 ford focus tdci
- Focus RS MK1 frontbumper
- Car Cutting Out
- Remote Central Locking woes
- rear door cards
- essex mappers
- mtx 75 billet selector fork
- question for Focus engine guru's....slight niggling issue
- focus mk2 head lights
- Superleggeras.......
- Which to get. 1.6, 1.8, 2.0 zetec s tdci
- Where is my Speed Sensor Cable for connecting a Kenwood Sat Nav??
- focus 1.8 zetec gear linkage adjustment
- 600+ BHP MK1 US spec Focus
- mk1 central locking problems
- Mrk 1 focus rs exhaust choice
- Pulling to the side, making whirring noises
- power steering pump
- p0423 ????????????
- 1.8 zetec tc light flashing
- Focus RS mk1 Paint Colour???
- Focus st 225 on 17" wheels
- 2011 US Ford Focus
- collapsed pcv hose
- where is the glow plug relay
- Colector Focus RS ?
- where are the glow plugs on 18tcdi
- 1.6 to 1.8 or 2.0
- Focus 1.6 rebuild
- coilovers
- Ford Focus issue
- Mud Flaps
- Focus Collection Model Bumper
- Power steering pressure sensor
- Mk1 FRS Bumper Grill
- ST170 recommended spoiler???
- ST170 front disks & pads, how much?
- 03 tdci cold starting problems - please help!
- Slave cylinder help :)
- ST170 dash clocks fitting
- help?
- rs bodykit??
- Engine system light
- plastic handbrake surround
- newbie with focus estate
- humming
- HID's for a 2007 Ford Focus TDCi
- focus dvd gps
- Greetings from Canada
- FRS Mk 1 Instrument Cluster Acting Weird!!
- Focus Estate MK2 rear lights
- anyone know of a breaking new focus RS?
- Big problem, advice please..
- ST170 duratec's thought they were strong engines...
- Tailgate spoiler and trim removal - 06 Zetec
- MK1 1.8 Zetec
- mk1 focus rs cambelt change??? modding tips??
- Refitting Standard Cams/pulleys
- Escort Sport/ZX3 engine swap...
- Replacing exhaust?
- I am Preperinfg My Focus for the Malta Ford 2011
- Power steering pump connection
- Going price for a 2nd hand FRS Flywheel
- focus headlights
- mk1 1.8 zetec rough idle?
- ST170 aftermarket bodyparts
- st170 cams?
- Focus RS Cam Cover
- Interior Question???
- Dashboard lights and inside lighting don't work
- Spark plugs for the 2.0ltr 16v blacktop
- Slow Tyre Deflation (Told not a Puncture)
- what power can frs mk1 internals take
- Focus Mk 2 1.8 Zetec Climate
- ST170 6 speed Getrag LSD, clutch & flywheel?
- WANTED Ford focus st170 inlet cam
- wheel bearings
- 2003 TDCI Fuel cut off switch
- TDCI non-starter....
- dial sweep
- 2000 Focus 1.8 TDCi Pre Heater light flashing
- engine problems
- wiper switch replace with 6 speed one
- what size wheels whith the 30mm eibach springs
- 2.0 in 1.8
- hi all
- focus timing belt.
- Negative camber on one Wheel!
- ford focus st3 (wont start)
- Considering a Focus RS (mk1) - Advice?
- ST170 headers AGAIN AND AGAIN
- Adjustable ride hieght suspension
- Wierd interior light prob.
- does this sound like there just trying to make a sale
- 1.6 Zetec SE engine variants - interchangeable cylinder heads?
- wiring diagram pump
- RS steering wheel
- MK1 1.8 Short Shift Kit
- fuel presure
- RS replica.....
- Ford Focus MK1 1999 Engine Squeaking Constantly
- Quick Focus Headlight Question
- can anyone please help focus 1.4 in a 1.6
- Sorry Team
- Mk1 1.8 and RS engine differences
- Frs exhaust
- focus rs500
- mt car upto date
- focus reverse lights
- White/grey smoke under deceleration?
- MK1 FRS Car Cover
- ST170 engine into a 1.6
- Need a new sideskirt for ST170
- mk1 zetec 1.8 problems help please
- Newbie
- ST170 Servicing
- Focus Rs engine
- MK1 Focus RS Knocking From Bottom End, or Gearbox????
- Focus and connect
- Double lock making horrible noise
- my new toy
- Rear Tracking.
- My focus 5dr 2.0 ghia (Picture heavy)
- Focus 1.8 TDCi Intercooler Hose
- Focus 1.4 05 RE-MAP help
- Focus st170 tuning pls?
- No working indicators
- Focus 2.0 fault code p0170
- 2-3 probs with new st170
- Mk1 Focus RS, original car mats??
- Focus gears to close together
- 'New' Focus RS front wings
- focus rs mk1 mods limit??
- Lambda and O2 Sensor Question!
- Mk1 Focus RS Problem...
- Rear trailing arm poly bushes
- MK1 RS induction kit+ standard dump valve???
- Spent some pennies on the focus
- focus knocking
- Focus Auto 1.6 (2000) help please
- Zetec Turbo Focus
- 03 focus 1-8 tdci wont start
- 2005 focus faulty charging system??
- mk2.5 mudflaps and wind deflectors?
- lowering
- focus rs mk1, problems
- Mk1 focus lx
- 1.8 Zetec Mk1, Sudden Loss of Power
- Buying Guide ST170
- confused...
- Anybody bought a rear diffuser for a mk2 frs
- 1.8 to a st170
- IB5 gearbox issue
- ST170 drive shaft/hub ????
- Ford Focus Central Locking Problem
- no drive after renewing clutch
- Engine Management Light
- MK2 RS Focus Dash Display Change!!
- TDCI Tuning, limits?!
- Focus turbo oil feed bolt
- Focus three blink indicators
- noise travelling down drivwshaft ?????
- 56' Plate ST H/L bulb
- Fuel Computer Fault 53 reg TDCI?
- hi any one help
- possible diff bearing change NEED HELP !!
- MK2 Focus upgrade
- st170 clutch advise please
- Blown Engine in Focus !
- Immobiliser key recoding
- Mk1 remote central locking
- Oil change
- mk1 focus rs power upgrade???
- Were's my Thread gone.....
- Problem with remote locking on mk2 focus tdci
- radio codes
- Focas Nearside Driveshaft.
- Frs mk1 carbon bonnet
- Squeek!!!
- Heated seats help please
- please please please
- focus 1.8 tdci egr valve cleaning
- GEM Module - Ford Focus
- headlights
- What FRS mk1 bits can be found on other everyday models?
- Anyone put a mk1 frs engine in a normal mk1 focus?
- Will a 1.8 engine run in a 1.6 focus
- Door Lock Replacement - UPDATE ordered one (post 6)
- Battery Remove / ECU Problem?
- HELP: MK1 FRS Bumper
- tappet settings, st170
- Whine from engine Comp?
- focus zetec window problem
- Focus Turbo rebuild
- 3rd break light
- Need help with RS-STspares.co.uk guys
- focus mk1 mk1.5 exhaust..
- 02 Ford Focus, DTC code P0171
- HELP: Getting standard rear springs back in mk1 Focus
- What mods and bhp on a standard mk1 FRS?
- aircon focus rs
- mk1 rs keys
- FFOC
- best pads mk1 focus RS
- sony mp3
- gearbox ratios
- ST Recaro seats
- Will undertray fit with front mount intercooler Focus RS
- Engine code for focus Rs engine
- Why oh why?
- power steering fluid
- fuse layout focus st 170
- Hello and quick timing belt queries
- shaped rear plates
- MK 1 Focus RS wont idle and cuts out!
- phase 1 pahse 2 whats the difference??
- help needed with gearbox
- ST170 Judders @2000 and 5000 RPM
- Mk1 FocusRS tuning... first steps?
- Mk1 FocusRS... which exhaust?
- st170 confused by sensor??
- Focus RS2 305 hp Compomotive
- just bought myself
- Focus ST170 Rear Caliper Rewind Tool
- Anyone bought these?
- 2010 Focus RS Dump Valve
- Help Needed !
- Just bought a mk1 FRS. Upgrade advice please
- FRS dash clock oddness
- AARRRRGGGHHHH - Now it's the clutch !!!!
- Steering Wheel Alternatives
- newbie here
- focus performance mods.
- Just looked at a new RS, To buy or not to buy?
