st170 brake disc change
hi all..pretty new here and also no mechanic but can easily follow instructions . i have an 04 st170 and have new pads and discs to put on it. thing is i cant find a Haynes for the St170. If i was to buy a haynes for the normal focus, would the process / instructions for replacing said parts be the same for my car or not?
Give people a chance, the focus room here is a quiet room.
To be honest a disc and pad change is the same as any car will be, remove the calipers and caliper carriers, whip disc off, new disc on, bolt the carriers back up, press pistons in, grease the sliders up, new pads in and bolt it all back up together, and adjust fluid level in reservoir as necessary.
cheers for the advise guys,
did manage to lend the windback tool of a guy at kwikfit,but he had the rong size fitting, so i tried exactly wot u said david....but no fooking chance..lol.
ended up lending another from a guy at a local garage...all done now...cheers again
JK12
33
26-04-2021 12:09 PM
